A-arm compatabilty
  • 2306 Views
Offline WVzuk
  • 181
A-arm compatabilty
« on: July 22, 2016, 01:54:54 PM »
So I bent my driver's side A-arm or suspension lower control arm.  I did this actually a while back but I am tracking down a pulling problem when braking. I know its likely the braking system that is responsible for the whole thing but i want to replace the arm to eliminate the variable.
I have a 1994 4door kick.  What other years are compatible?  Are the two doors the same?  Anyone want to sell me one?
Jon
Re: A-arm compatabilty
« Reply #1 on: August 24, 2016, 11:30:15 AM »
I don't have a book to compare part numbers, but I would guess 89-98 would all be compatible, across the 2 door and 4 door lines (excluding the sidekick sport models).
Hopefully someone that has access to part numbers will reply to confirm.
« Reply #2 on: September 08, 2016, 01:22:56 PM »
I don't have the part numbers but I can tell you we have swapped them around between years and models.  So you should be good.  :)
I do not believe there is a change unless you go to a Sport or 2nd gen model.
