A-arm compatabilty
A-arm compatabilty
WVzuk
181
A-arm compatabilty
July 22, 2016, 01:54:54 PM »
So I bent my driver's side A-arm or suspension lower control arm. I did this actually a while back but I am tracking down a pulling problem when braking. I know its likely the braking system that is responsible for the whole thing but i want to replace the arm to eliminate the variable.
I have a 1994 4door kick. What other years are compatible? Are the two doors the same? Anyone want to sell me one?
Thanks
Jon
1994 4dr Sidekick: 3inch Zukination lift, 30x9.50 mud tires, snorkel, ARB rear locker, homemade bumpers
Skyhiranger
3734
122
I don't buy, what I can build
Re: A-arm compatabilty
August 24, 2016, 11:30:15 AM »
I don't have a book to compare part numbers, but I would guess 89-98 would all be compatible, across the 2 door and 4 door lines (excluding the sidekick sport models).
Hopefully someone that has access to part numbers will reply to confirm.
Drone637
8121
116
Evil Cow
September 08, 2016, 01:22:56 PM »
I don't have the part numbers but I can tell you we have swapped them around between years and models. So you should be good.
I do not believe there is a change unless you go to a Sport or 2nd gen model.
