kick/trac front locker
  • 2468 Views
Offline SnoFalls
  • 1358
« on: March 07, 2005, 07:17:56 AM »
In order to use a detroit or lockrite, I need to get a samurai rear carrier (+ have it machined)?
Also, since up front I've got 22 spline shafts, I'd need newer model cv's (to match the 26 spline sami side gears)
While I'm doing this I probably should consider a steel 3rd housing from a Grand Vitara as well as a steel Diff housing from a XL7 ...
I'd also like to mod so a left axel can bolt over to the right side too.
Really starting to add up in $$$
Offline chet
  • 556
  • Zuki time!
Re: kick/trac front locker
« Reply #1 on: March 07, 2005, 09:29:33 AM »
so whats your question?  ;D I am looking at  the same thing. You don't need to go to 26 spline right away your 22 spline sidegears will work in the sammy carrier.
Offline SnoFalls
  • 1358
« Reply #2 on: March 07, 2005, 09:36:15 AM »
I guess I forgot that ... :)
Just trying to fathom if I figured it all properly?
Staying with 22 spline side gears would be best since I have spares there already ...
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #3 on: March 07, 2005, 09:59:15 AM »
the_dude
« Reply #4 on: March 09, 2005, 04:49:36 PM »
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #5 on: March 09, 2005, 06:12:09 PM »
If you buy the 3rd from a V^ wont that have 26 spline side gears?
Wont the locrite fit in that with a ring and pinion change
just a thought
Markyb (UK)
UK Vitara JLX SE
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #6 on: March 10, 2005, 02:38:25 AM »
Make sure you get an 88 an older one w/ the 4 pin carrier.
