bending strut tower (fixed)
  • 9 Replies
  • 3338 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« on: March 08, 2005, 03:26:32 AM »
my strut tower is bent any suggestions on how to bend it back. i don't want to use haet because that will severlly weeken the steel. any idea for tools would be helpful. i know how to do this i am just checking to see if maybe someone else has done it differently/easier before.
« Last Edit: March 09, 2005, 05:39:46 AM by tracker8wr »
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline zookiemike
  • 474
  • $,reppin Michigan,$
Re: bending strut tower
« Reply #1 on: March 08, 2005, 07:38:45 AM »
Get a come along and a tree 8).
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #2 on: March 08, 2005, 03:32:16 PM »
Canadian version: tree+chain+reverse= problem solved ;D ;D
Kidding, if it's not really bad maybe try a porta power (bodymans jaws of life)
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #3 on: March 08, 2005, 07:21:04 PM »
Hey, that'd be the dutch version too  ;D At least that's the way I straightened up the inner body panels when I hit another car doing about 70km/h  ;D
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Natebert
  • 1098
« Reply #4 on: March 09, 2005, 01:07:45 AM »
US Version.
Tree + Chain + Reverse = Feds + Greenies at your front door.
Offline tracker8wr
  • 568
    • my home page
« Reply #5 on: March 09, 2005, 05:37:31 AM »
i cut a plate drilled 4 hole three to mount it to the tower and one to mount a big ass i hook in i welded the i hook together and to the plate. i used a percision 1/4" comealonge (for every notch on the comealong it has a 1/4" of line pull) i had from our old fabshop. i made a 3' long drop bracket for a 2" reciever with and tab to hook the comealong to. and put it on my jeep cherokee and used it as the anchor. every thing turned out fine and by haveing the reciver bracket it alowed me to change positions i was pulling from. worked great took about 30 min. to fab all the tools but helped a lot.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline jzap
  • 515
  • How difficult can it be?
Re: bending strut tower (fixed)
« Reply #6 on: March 09, 2005, 11:52:43 AM »
My version:
Chain, comealong, Kids basketball goal ( 3 inch steel pole set in 800 lbs of concrete and filled to the top with concrete)...
Results...  ...Pulled pole over...   ...had to finish by using tree...
« Last Edit: March 09, 2005, 11:53:30 AM by jzap »
Jim Z.
66 Apache camper
Offline Natebert
  • 1098
« Reply #7 on: March 09, 2005, 02:10:02 PM »
Is the hood beautification the results of the basketball hoop?
Offline jzap
  • 515
« Reply #8 on: March 09, 2005, 02:38:57 PM »
Nope!!!  Eight point buck at 50 MPH...  ...That's why I was pulling the front end...
When the comealong suddenly started getting really easy to crank, I noticed that the pole was starting to lean, so I unhooked, moved the Zuk and pushed it over by hand.
The kids are grown and out of the house.  I had taken the backboard and hoop down last year, and my wife and I had been wondering how we were going to get that pole out of there :)
Here's the before and after pics:
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1110222043
« Last Edit: March 09, 2005, 02:47:11 PM by jzap »
Jim Z.
66 Apache camper
« Reply #9 on: March 09, 2005, 09:57:58 PM »
;D That's great  ;D I used a telephone pole, It's hard to pull those over and the bark is already stripped off ;)
