Running without 02 sensor
  • 2327 Views
Offline Dihnekis
  • 398
« on: December 31, 2005, 05:36:46 PM »
I'm looking at doing the 1.6L 8v swap in my samurai soon, and I've got ab it of problem. I was going to put a header  sensor in at the same time, but the header's collector has no spot for an 02 sensor. How bad will it hurt me if I go without.
1988 Suzuki Samurai
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Running without 02 sensor
« Reply #1 on: December 31, 2005, 05:48:03 PM »
Think the worst case of oxygen sensor fouling ever...that's what the computer will think.
It'll put itself into limp home mode if it has one.
Offline Yoak
  • 577
« Reply #2 on: December 31, 2005, 11:14:53 PM »
I ran my 8V with the sensor blow for awhile, and it would give some check engine errors, but ran fine
Offline Dihnekis
  • 398
« Reply #3 on: January 01, 2006, 01:01:19 AM »
Ok I will try and use it, but i don't know for sure.
1988 Suzuki Samurai
« Reply #4 on: January 01, 2006, 01:05:56 AM »
just drill a hole in the collector and weld a bung on it and your done, they  might have one at the local muffler shop, I'm sure they can get one. If you have to weld it low on the pipe wrap the header with some of that heat tape stuff.
Offline takai
  • 907
« Reply #5 on: January 01, 2006, 10:08:52 AM »
That is a good idea. I think that you will find that running without an O2 sensor is not a really great idea. It can be done but, they were put there for a reason. (Unfortunately ;D )
'Cause, I am to misbehave.
Offline da_tub
  • 307
« Reply #6 on: January 01, 2006, 06:28:37 PM »
how bout you go to the wreckers and get  one with a port... or order a new calmini header.... no o2sensor means shitty preformance,,  not to mention fuel mileage just went down the toilet..... just my 2 cents
91 four door ,and some stuff
