tracker sidekick interchangability
  • 1604 Views
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« on: January 01, 2006, 01:16:52 PM »
Does any one know if I take a instrament cluster out of a sidekick and put it in a tracker will the 4x4-L indicator work in the tracker??
I licked the L indicator in my sidekick and would like it in my tracker if it would be easy to do. anyone ever swapped these and noticed if the L indicator works in a tracker??
Offline Yoak
  • 577
Re: tracker sidekick interchangability
« Reply #1 on: January 02, 2006, 01:09:09 PM »
They will swap out,
but the problem is different clusters have different connetions in the back
I have a 93 tracker, had no tach....
Found a cluster w/ tach and eveything..but different connetions on the back
Found another tach, same connections and everything workds just fine....
So it can be done you will just have to search
  • 264
    • Cardomain site
« Reply #2 on: January 02, 2006, 03:23:53 PM »
I know that they will interchange with no problem I was trying to see if the Sidekicks 4x4-low indicator will work if installed in a tracker
