1.3 to 1.6 ideas
  • 0 Replies
  • 1347 Views
Offline thedeep
  • 50
1.3 to 1.6 ideas
« on: January 02, 2006, 10:39:36 AM »
Hey guys,
   Got my 1.3 engine out of the Sami. Just waiting for the salvage yard to get the 1.6 pulled out of a '92 Tracker. Got a Rocky Road conversion kit ready to install. I've got the starter and alternator coming with the engine. Are the front end/fan/fan housing the same? Anything else I should be concerned about? I'm moving my reworked 1.3 intake manifold with the 38 DGAS Weber to the 1.6 along with the Calmini exhaust. Suggestions? Thanks.
   Oh, I will very soon have the 1.3 block (great shape), pistons, with rings, head, etc available. The oil pump went south taking the rod bearings with it. The crank bearings are showing signs of wear. I'm fairly certain the crank will have to be turned, but it is currently stock so there should be plenty of metal to work with. Need a new DAMNED oil pump! This engine only had 2500 miles on a full rebuild! It had new pistons, rods, rocker arms, valves, etc at that time. If interested drop me a note. If no one is interested I will just put it all on Ebay. Thanks.
