1.6L 16V in a sammy
  • 1651 Views
Offline fallguy
  • 127
1.6L 16V in a sammy
« on: January 02, 2006, 11:51:15 AM »
hay guys  im going to be putting the 1.6L in the sammy with the sidekick
5 speed and a kicker3  what motor mounts would you use and which oil pan
the 1.3L or the stuff out of the sidekick 1.6L ?  also will i need to put a body lift on to
clear the 1.6l fuel injection so the hood closes  it looks like the 1.6l is a littel taller
        thanks
Offline Dihnekis
  • 398
Re: 1.6L 16V in a sammy
« Reply #1 on: January 02, 2006, 12:49:07 PM »
You will need a small body lift in the front, unless you cut the crossmember out of the hood.
You can use modified dodge 318 motor mounts, or buy an adapter kit from someplace like petroworks, they give you new motor mounts. If you have more than 3-4 inches of lift, don't worry about the oil pan, just use the 1.6L one.
If you get the petroworks kit you wont need a body lift.
1988 Suzuki Samurai
Offline rkteckt
  • 214
« Reply #2 on: January 04, 2006, 02:54:52 PM »
Heres a novel idea......
Lots of Samurai owners make the switch to the 1.6.....Some of them start with two running vehicles before the swap, but ususally the donor zuk is trashed out or wrecked or something.
Has anyone ever tried to install the samurai engine into the donor vehicle?
Can it even be done?
just curious, i've been wanting a larger slower less powerful zuk...... :-)
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
« Reply #3 on: January 04, 2006, 04:11:22 PM »
ROFLMAO  ;D
