Rough idle/missing
  • 1713 Views
Offline ArkansasTracker
  • 85
Rough idle/missing
« on: January 02, 2006, 12:38:15 PM »
Finally pulled the EGR and cleaned out all the black I could (I got the EGR code from Autozone and was trying to avoid $100+ for another one).  Reinstalled and went for a drive soon after and when sitting in the driveway it idled rough and almost died while sitting still.  Need a new one?
I also happened to check the coolant later that day (which I had just topped off a couple weeks ago) and the overflow was empty again.  Using coolant?  I haven't seen any puddles on the ground yet, but I parked it in the garage this time to check for sure.
Any help would be appreciated (before I trade it for one of the 4 doors I've found!).
Thanks,
Jerry
'96 Soft Top Geo Tracker, auto (leaking), coil spacers, 30X9.5 Mud Rovers
Offline Yoak
  • 577
Re: Rough idle/missing
« Reply #1 on: January 02, 2006, 12:57:25 PM »
Jerry,
my kick was ideling rough some time back,
and changing out the plugs and wires fixed it for me...
..I acually had a wire arching to the engine head.....
Not sure if you've tried this yet,
Are you getting any other error codes from your ECU?
  • 85
« Reply #2 on: January 03, 2006, 04:56:20 PM »
Not yet.  No error codes have shown up since the EGR code.  Could a code show up without the check engine light coming on this time?
Any idea on the coolant disappearing??
Honestly, it probably could use a good once over (plugs, wires, belts, hoses, etc.).
Thanks for the input.
