The motor of samurai is squashed
  • 1828 Views
Offline ChileKick
  • 75
  • DIYer Man !
    • Nacion 4x4
« on: January 04, 2006, 10:21:07 AM »
Gentlemen I have a problem.  it makes a good time the motor sometimes is squashed completely when it goes in one climbed, is samurai 2.  I go to 4000 or 5000 rps hardly and lower completely rps. I have changed to several times the benzine filter and nothing to him.  A test to the pump was done to him that goes in the pool, and also throws good pressure has washed to the pool and nothing.  Single it happens to him sometimes.  It is thanked for, some aid
Custom 5" suspension lift,custom 2"body lift, custom transmision lift,custom intake porting and custom exhaust.
3" wider A-arms custom made front coils.Power inverter , dual batteries , 8000lb winch , VHF , AM , LSB , On board Notebook-GPS on 15" Screen :-)
 265/70 - 15 tires on 8 rims. Custom Man
Offline 94track
  • 212
Re: The motor of samurai is squashed
« Reply #1 on: January 04, 2006, 02:01:35 PM »
i am taking it that you mean fuel filter, ( i hope at least). If you have good fuel pressure, start looking for other things.  All vacuum lines in good shape, also i would give it a good tune up, plugs, wires, cap, rotor.  Also what type of vehicle is it
« Reply #2 on: January 05, 2006, 04:45:52 AM »
Is this a carb model or injection?
Offline berny
  • 16
« Reply #3 on: January 06, 2006, 08:02:36 AM »
THE JEEP IS WITH INJECTION
