HELP
  • 12 Replies
  • 2698 Views
Offline linx
  • 29
HELP
« on: January 04, 2006, 09:54:09 PM »
hey all
I need some help with a suzuki siarra , with a 1600cc vitara motor in it !
it had the new motor put in a short while back and it was all fine untill about 2 weeks ago.
Te car started to rev up and down by itself when i switched the lights on , but it WAS fine when i drove it in the day with no lights , but today it started to do the rev thing when the lights were off,  and now isnt ideling well at all..
anyone got any ideas on what it could be
the revs go from 1500rpm to 2500rpm up and down continuously.
thanks
Offline linx
  • 29
Re: HELP
« Reply #1 on: January 04, 2006, 10:22:22 PM »
anyone???????????
i cant drive the car much atm in fear of wreckin it .
HELP
Re: HELP
« Reply #2 on: January 04, 2006, 10:45:00 PM »
Is it cold where your at? where ever your at(hint hint) there is a small line or hose that runs from underneath the intake manifold to your intake tube over to your idle air control valve and back(small black hose should be warm to the touch after warming the engine up)the valve that controls the heat to it is under the manifold close to the fire wall, this valve could be cloged.
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: HELP
« Reply #3 on: January 04, 2006, 10:56:02 PM »
He lives near me, and i live in Darwin, N.T AUSTRALIA.
its hot where we are!
Offline linx
  • 29
Re: HELP
« Reply #4 on: January 04, 2006, 10:59:37 PM »
yea im up in da hot in darwin .
wont be clogged with ice or the like but maybe mud or dirt?
Offline linx
  • 29
Re: HELP
« Reply #5 on: January 04, 2006, 11:06:22 PM »
i took most of the ones i could off and blew threwq them and they all seemed to be fine , any other ideas?
Re: HELP
« Reply #6 on: January 04, 2006, 11:08:42 PM »
ok, well if you suck any water through your maf unit it will mess it up, or if you over oil a k&n filter could do it, check your tps and coolant sensor, allmost sounds like a bad ground or computer(ecm capacitor problem) open the ecm up and smell if it is burnt or can see leakage of one or more of the caps.
Re: HELP
« Reply #7 on: January 05, 2006, 12:13:40 AM »
Trying to read the fsm and it has everything thing in there to check which sounds like everything, from egr valve leaking too much, damp ecm,water in ecm, loose connector on ecm,engine not up to running temp,coolant sensor, o2 sensor contaminated, ect.
Offline linx
  • 29
Re: HELP
« Reply #8 on: January 05, 2006, 01:29:32 AM »
thanks ill have a look tomorrow and c what i can find , thanks
Offline SiKiD_01
  • 574
Re: HELP
« Reply #9 on: January 05, 2006, 02:11:06 AM »
Linx's sierra has a 1.6L vitara motor in it. its an 8V carby motor, not injected. and he is using the stock sierra/sammy airbox in the stock location.
Offline SIERRA BANDIT
Re: HELP
« Reply #10 on: January 05, 2006, 03:08:58 AM »
ben taking ur dads car without permission again ay?
could it be the thing you removed 2 keep the engine cooler. the thing that allows more coolant through.
Offline SiKiD_01
  • 574
Re: HELP
« Reply #11 on: January 05, 2006, 03:53:07 AM »
the thermostat? i dont think so. it might have something to do with the idle up for the air con, or something like that...
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: HELP
« Reply #12 on: January 05, 2006, 02:31:43 PM »
Linx:
Does your Sierra have a Hitachi Carburetor?  If so, these bugger can get tempermental in their old age.  They have a LOT of vacuum hoses, check valves, etc. that can go bad and generally ruin performance.  Also, they are set up for the 1.3 and you may have some performance problems with it feeding a 1.6 8-valve.
Try looking at Section 5 of the Samurai FSM for info on servicing the Hitachi... which you will find by checking out the web site in my signature  ;).  Search for fsm and select the second .pdf file.  It's a long download if you are using dialup.
I hope to have a comprehensive Hitachi Carb vacuum line article posted real soon!
Hope this helps!
Ack
