Anybody using hood pins on a Track/Kick?
  • 2703 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: January 06, 2006, 08:47:39 PM »
Anybody used hood pins on their Track/Kick?  My hood latch is...problematic...at best.  Any time I close it the amount of time it takes to get the latch to release is a guess...could be 5 minutes...could take me walking away and coming back the next day before it opens.  So I'm thinking about other options.
What'd you use?  Where'd you mount them?  Hints/Tips?
Offline jzap
  • 515
  • How difficult can it be?
Re: Anybody using hood pins on a Track/Kick?
« Reply #1 on: January 06, 2006, 09:23:20 PM »
Once again...  "last year, after I whacked a deer with my '96 Tracker" (third after crash story tonight...), i temporarily fabricated a set of hood pins to hold the hood down until I got it fixed.
I twisted the rubber stops out and used two nuts on each bolt and washers to fasten a couple long bolts to the crossbar at those holes.  I cut the bolt heads off and marked the locations on the underside of the hood by spraying white paint on the cut ends and lowering the hood onto the wet paint.  Then I drilled holes in the hood so the bolts would pass through the holes when you lowered the hood.  Then, with a pair of shock absorber washers in place, I marked the location on the bolt shaft and drilled holes through the bolts.  A pair of spring clips through the holes held the hood down.
I used bolts with a smooth shoulder , so I didn't have threads sticking through the hood, and smoothed down the tops of the cut off bolts with a Dremel tool.  I used the setup for a few months until I got a replacement hood and latch.  It kept the hood down, but it was a PITA checking the oil.  I was glad to go back to the stock setup.
You can probably junkyard a latch pretty cheap, and they are easy to change.  If it is your cable that is messed up, you can use some light bar stock to fabricate a release handle behind the grill. Either way, I prefer the stock hood latch.
« Last Edit: January 06, 2006, 09:32:46 PM by jzap »
Jim Z.
66 Apache camper
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: January 07, 2006, 09:10:51 AM »
Simpler is better in my book.  Getting sick of dicking with this thing, and if the hood stays down once more I might just blow the whole thing up.
Besides, I heard from a kid with an Erector Set wing on a Honda that hood pins give you 20hp.  Any truth to this? ;)
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #3 on: January 07, 2006, 12:20:28 PM »
More like 18hp, but I guess he was rounding up to make it sound like more.  :o  ;D
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: January 07, 2006, 04:18:08 PM »
Hmmm, so maybe I didn't loose 20hp when I took off the cheesy exhaust tip?  Maybe only like 15-17hp? ;D
Offline wolf66
  • 193
« Reply #5 on: January 08, 2006, 07:47:40 AM »
No, losing the fart exhaust is like losing 50hp i think.......or is it like gaining 50 IQ points....I forget.... ;D
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: January 08, 2006, 08:14:11 AM »
It wasn't a fart can muffler, just a fart can tip, can't be worth even half of 50hp...I hope.  Maybe my engine troubles are the ricer-gods punishing me for removing the tip? :-\
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
« Reply #7 on: January 08, 2006, 08:50:15 PM »
I run hood pins on the Goblin. It's latch was questionable as to whether it would stay latched, the hood shook so bad at speed! I grabbed a pair of pins from the hood of a 60's Bronco at a local salvage yard and just mounted them right behind the rubber screw in pads at the front corners. Work great and definately keep the hood closed!
