Fuel filter location
  • 3982 Views
Offline paps133
  • 166
  • make your own road..
« on: January 08, 2006, 07:22:23 AM »
Hey guys, i've got a stupied question.
I'm trying to firgure out where my fuel filter is. Is it the black pop can looking thing mounted in front of the fuel tank. ??????
I've also got another problem, the black pop looking thing is leaking where the fuel line is connected to it. I've figured that its the copper bushing. But its sunday and nothing is open, and i need my tracker to go to work tomorrow. I was wondering could i just put a different type fuel filter in, and just cut that one out. Thanks for your help.
Offline wolf66
  • 193
Re: Fuel filter location
« Reply #1 on: January 08, 2006, 07:38:49 AM »
Its the gold looking can in this picture and I would try to swap out the stock one, get some new washers and carefully put it on tight.
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline paps133
  • 166
« Reply #2 on: January 08, 2006, 07:53:10 AM »
Yes it is that black thing in the picture, But i can't get one today because everything is closed.
WOuld one of those big clear plastic ones work until i got a new stock one?
Sorry for the newb questions.
Thanks
Offline wolf66
  • 193
« Reply #3 on: January 08, 2006, 08:09:03 AM »
Well the stock fuel hoses are threaded and the EFI fuel pressure is pretty high....
maybe crawl under and see if you can tighten (losen it up 1st) the fittings, then add a new one w/ new washers on Mon.......how bads it leaking?
Offline paps133
  • 166
« Reply #4 on: January 08, 2006, 08:20:26 AM »
it's leaking pretty good, so what ur saying is i would be wasting my time putting in one of those plastic ones in.
I've got the hose, for the fuel line. but it's the filter i'm worried about popping. thanks
Offline wolf66
  • 193
« Reply #5 on: January 08, 2006, 09:43:39 AM »
Even the hose has to be EFI rated, reg fuel line for carb'ed use runs at under 10 psi while EFI runs 50-80 psi
Offline paps133
  • 166
« Reply #6 on: January 08, 2006, 10:52:38 AM »
i went down to candain tire, and they had a afteramrket fuel filter in stock, even came with the copper bushing that i need it. Thanks for the help.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: January 08, 2006, 12:18:13 PM »
That's funny, my 92 doesn't have one of thoes. I'll have to look into this.
Offline wolf66
  • 193
« Reply #8 on: January 08, 2006, 02:27:24 PM »
Mines a '96, your location may vary based on type of EFI or carb...
