Steering parts
  • 1703 Views
Offline puddlejumper
  • 40
  • Hummer escape pod.
Steering parts
« on: March 08, 2005, 11:23:21 AM »
Hi everyone.
I am finishing the repairs to my truck from the accident, and I need to now replace the center link (from gearbox to idler arm) and the idler arm itself.
Where can I get these parts other than the dealer or used?  I am fine with an upgrade as I am now going into INSANO MODIFIO mode, but I didn't even see any better stuff on Calmini.  If I just missed it let me know, otherwise where can I get some better steering components for my sidekick.
Also, will 33 inch tires frag the drivetrain on this thing?  And if so, what are the weaker links from your experience wheeling these oversize ATVs?  I am not worried about hitting parts on rocks, just the twisting force from the engine/trans with the T-case in LOW.   Of particular concern are the CV joints, which would be a pain to modify, but I do have some ideas.
Thanks!
My other car is a Freightliner.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: Steering parts
« Reply #1 on: March 08, 2005, 12:11:05 PM »
here is a power steering setup on ebay with a pitman arm  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7959955697&category=33642&sspagename=WDVW  or go to www.hawksuzukiparts.com or www.aftermarket 4x4.com
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: Steering parts
« Reply #2 on: March 08, 2005, 03:53:45 PM »
Weaker links running 33's are usually kept to the front axle.  The list usually starts with the inner CV cage, then the Aluminium axle housing, then the small 22 spline axle shaft (Pre 96).  Their are many people getting away with running 33's in stock form, it all depends on how hard you drive.   Their are parts available to overcome nearly all these weak links.
