oil pump question
  • 4 Replies
  • 1900 Views
Offline zuki4fun
  • 91
  • luv machine
oil pump question
« on: January 12, 2006, 07:25:48 PM »
will a 1.3 oil pump work in 1.6 8 valve?
Re: oil pump question
« Reply #1 on: January 12, 2006, 10:20:51 PM »
There is a slight difference in the output port
of the 1.3 pump, tho I don't know why. I think
they will interchange, but there could be differences
in the swept volume of the pump and/or pressure
relief valve settings.  I know the 16V OBDII needs
a crank position sensor, and that pump is different
in the housing design, as well as is the oil pan.
Make sure the gasket fits the pump body correctly
before you put it on, don't want any leaks there, it
could get really messy
Offline zuki4fun
  • 91
  • luv machine
« Reply #2 on: January 13, 2006, 12:15:24 PM »
i thank you again i m not having luck with this motor i just rebuilt it and im thinking im going to bite the bullet and hope to find another motor its realy hard to find motors for these things that acually run good so if you know of any let me know im going to play with this one agian and see if i can get it up and running i miss driving my sidetrack
« Reply #3 on: January 13, 2006, 07:01:40 PM »
What problem are you having ?
Why do you need/want to change
the oil pump ???
Offline wedge
  • 38
« Reply #4 on: January 13, 2006, 11:14:47 PM »
I'm changing the oil pump in my 89 as soon as the part gets here because the seal around it is leaking, and if I take it apart, I'd rather spend the 90 bucks and not worry about an oilpump failure.
