Engine Choices
  • 2067 Views
Offline takai
  • 907
Engine Choices
« on: January 14, 2006, 02:03:28 PM »
The Sammy needs a new engine. No ifs, ands or buts. Looking for input on which way to go. Would love to go to a diesel but, a little to expensive and time consuming right now.
I came up with two likely choices
1)1.6 16-valve (TT to do the work, engine wil have about 70-90K on it)
2)1.6 with a 1.3 head and a Phase 1 torquer cam. (Fresh rebuild, and I can do myself over a weekend)
Any comments or other ideas.  I have a weber to put on the second option already, and my exhaust is already shot so that isn't a real factor. (It resembles swiss cheese and will have to be replaced anyways  ;D ).
I will need to maintain mileage. Lots of travel back and forth to work. And I think I can I can due the second one for a little less $$. Am I going to notice enough of a difference between these two set-ups to really care? I think a Yugo actually passed me on the freeway the other day so I know the both will be a definite improvement.  ;D
'Cause, I am to misbehave.
Re: Engine Choices
« Reply #1 on: January 14, 2006, 04:03:14 PM »
I say 1.6 16V, keep it in standard trim and it should be set up right and 100% reliable , maybe more so than in a Track/Kick as it has less work to do. The other set up will need experimenting with to get the right carb and ignition settings
Offline Jeff@TireBalls
  • 559
Re: Engine Choices
« Reply #2 on: January 14, 2006, 05:54:45 PM »
I thought that the diesel swap was easier than my old 16V swap.
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Re: Engine Choices
« Reply #3 on: January 15, 2006, 01:32:53 AM »
aftermarket 4x4 had a used diesel for sale with the acme kit for 1200,  not too bad.
Offline takai
  • 907
Re: Engine Choices
« Reply #4 on: January 15, 2006, 08:55:46 AM »
Do you have a link for that?
