suzuki samuria spring over axel conversion (steering arm)
  • 2551 Views
Offline kris20970
« on: January 19, 2006, 08:51:14 AM »
hi ive got a suzuki samuria i have a 3" body lift  shackel lift and spring over axel lift which i have just carried out my self.
PROBLEM: I CAN NOT GET THE STEERING ARM TO FIT DOES ANY ONE NO HOW TO GET IT TO WORK PLEASE HELLLLLLLLP!!!! thanx kris.  :(
Offline Ian
  • 50
    • Island Rock Crawlers
Re: suzuki samuria spring over axel conversion (steering arm)
« Reply #1 on: January 19, 2006, 10:03:44 AM »
Not really clear on what you mean by can't get the arm to fit.  Is it the stock steering arm you are trying to attach to the knuckle or are you trying to re-attach the drag link to the arm after you lifted it?  With that much lift you will need some sort of steering correction.  At a minimum a Z link (dropped drag link) would be needed however you should consider installing cross over steering for best results and safety.
Offline kris20970
« Reply #2 on: January 19, 2006, 10:27:26 AM »
please could you tell me were i could get some steering from ? and yes im using the stock arm  thanks kris.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: January 19, 2006, 11:28:31 AM »
Check out http://www.breezeindustries.com/suzuki.htm for an excellent draglink.  I have one on my 4.5" SPOA.
Ack
