Drivetrain VIbration after suspension swap
  • 3028 Views
Offline rkteckt
  • 214
« on: January 27, 2006, 10:17:23 PM »
Hi there,
I finally got rid of the terrible homemade SPOA that was on my Sammy when i bought it.  I replaced it with a RRO jp-eater spring under supreme kit.  Everything is great except i have a new vibration when i let up on the gas while driving.
It happens as I go from accelerating or coasting to engine braking....the second the engine starts to brake i get a harsh/loud vibration through the body.
I went from a 6" lift to a 5" lift so i cant imagine that the drive shafts need spacers.
DOes anyone have any ideas?
thanks
Chris
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
Offline da_tub
  • 307
Re: Drivetrain VIbration after suspension swap
« Reply #1 on: January 27, 2006, 10:26:03 PM »
diff angle is off,, you will have to shim it. i belive
91 four door ,and some stuff
Offline rkteckt
  • 214
« Reply #2 on: January 27, 2006, 10:35:14 PM »
Thanks, I'll yell at the Mechanic when i take it back to have the bolts tightened on the u-bolts.
2005 Avalanche Z71
2003 Matrix XRS
Offline da_tub
  • 307
« Reply #3 on: January 28, 2006, 12:48:35 PM »
why? were  they loose? that could be the problem also if that was loose... could be bad u joints also.. if all that checks out.. i'd look at shimming the rear diff a bit..
Offline rkteckt
  • 214
« Reply #4 on: January 29, 2006, 07:10:21 PM »
Oops,
The installation instructions for the RRO kit says go back in a few days and tighten the u-bolts......They are not loose as far as i can tell.
2005 Avalanche Z71
2003 Matrix XRS
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #5 on: January 29, 2006, 08:10:45 PM »
did your drive shaft fall out of its slip joint when you did the conversion?
a mate had his drive shaft slip out un-noticed, and when installed back, the uni joint yokes were a couple of splines off, and was close to what you describe.
if its not that, the your uni angles at the transfer and diff are unequal.
Offline rkteckt
  • 214
« Reply #6 on: February 01, 2006, 10:23:41 AM »
Ok, Got it fixed,
It was a bad diff angle like you suspected.
Runs great now, the new springs are a huge improvement over the stock springs.
Nothing can fix the short wheel base low weight problems with ride quality, but my tires can ride up and over large bumps now without ramming  the whole body upwards.
Ride is still stiff but more comtrollable, much greater articulation than stock of course.
Thanks for all your help
chris
2005 Avalanche Z71
2003 Matrix XRS
