Quik Third member question?????
  • 1910 Views
Offline blakester1123
  • 95
  • 88 sammy 6in on 32s and rising
« on: January 29, 2006, 08:25:10 PM »
Are the front and rear third members the same just different guts? can i take a front third housing and pinion and put my rear ring and spider gears in it?
  • 95
Re: Quik Third member question?????
« Reply #1 on: January 30, 2006, 12:50:03 PM »
ummm this would be for a samurai
« Reply #2 on: January 31, 2006, 01:37:14 PM »
I believe the only difference on the Samurai is the spider gears having a different spline count.  If you swap your front axels out for the larger spline you could have the same front and rear diff.  :)
Offline darnold87
  • 351
  • 11
« Reply #3 on: January 31, 2006, 01:47:20 PM »
I'm not positive, but I believe the rear axle shafts are 26 spline and fronts are 22 or 24 spline.  All you have to do is use the original spiders from the rear and put them in the front third member and you're good...
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
  • 95
« Reply #4 on: January 31, 2006, 07:57:23 PM »
cool thanks, little late on the advice though auction ended on ebay for front third housing. oh well
