front locker questions
  • 29 Replies
  • 8166 Views
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: front locker questions
« Reply #15 on: February 02, 2006, 07:22:12 PM »
  YA, the Trail Tough locker is a 3 pin design where as the sammy is a 4 pin design.
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #16 on: February 02, 2006, 09:03:19 PM »
I don't think they actually sell a front lockrite for the kick but since you use your own sidegears does it matter? ???
Trail Tough sells a locker for Kick front . . .
http://www.trailtough.com/sidekick.htm
finally im stoked im buying one next week
Offline 1bigtracker
  • 3409
« Reply #17 on: February 03, 2006, 06:07:56 AM »
ahh thanks for clearing that up ;)
Stu
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #18 on: February 03, 2006, 10:21:15 AM »
TRailtough locker is on order. I will let everyone know how it works soon ;D ;D
     Kevin
Offline binkie
  • 46
« Reply #19 on: February 04, 2006, 09:04:51 AM »
This is an interesting article featuring the disadvantages of the auto-lockers.  It looks like the auto-lockers use a synchro that locks up after a certain amount of spin.
They do not as easily "unload".  When I saw the price of the lockright, I did a lot of web-surfing to check it out.
http://www.off-road.com/suzuki/reviews/rrarb.htm
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #20 on: February 06, 2006, 08:58:13 AM »
Binke, I have a lockrite in the rear of my kick and It does sometimes windup and unload but not too bad. I'm buying a front locker and since you have the front hubs unlocked on the street I shouldn't have much trouble.
   Kevin
Offline binkie
  • 46
« Reply #21 on: February 08, 2006, 07:10:57 PM »
I guess it would be an excellent solution for the front diff.  Will the Lockrite fit in a 2002 GV with Manual Tans?
What is the difference between the Auto Transmission differentials and the Manual Transmission differentials?  Is it the spline sizes going in, or just the gear ratio?  Or is everthing different?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #22 on: February 09, 2006, 08:45:36 AM »
Just the gear ratio is different. I have the new Trailtough locker in my hand and all the steel parts on my bench so after the Calico trip I will be putting my 5.83's on the locker and into the GV 3rd member then into the steel housing. I'm also doing the widening at the same time. ;D ;D ;D
   Kevin
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #23 on: February 09, 2006, 08:51:16 AM »
NICE!!
I want to hear all about the behaviour of the lockrite in the front, as soon as you get it in!!!
Offline gv1600
  • 83
« Reply #24 on: February 09, 2006, 10:42:25 AM »
ppltrak, i ll be glad if u get photos from that mod that you will do.
i own a GV with steel frond housing and third and i,m planning to lock the frond too.
Suzuki GV Calmini 2,5'' - Full Steel V6 Frond Diff - 205/80/16 KL71 -
4.24 t-case - T-Max 6500 - VTTR Snorkel - ProTrack Air-Lockers F/R
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #25 on: February 09, 2006, 11:50:52 AM »
OK I'll post picks when I get back on tues.
     Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #26 on: February 09, 2006, 12:22:59 PM »
Hey GV 1600, You have a vacume operated front diff. I don't know if you can just replace the carrier with one like the trailtough locker or a sammy carrier. Probabally you can but you'll have to put on manual hubs.
     Kevin
Offline binkie
  • 46
« Reply #27 on: February 09, 2006, 07:44:35 PM »
The GV has a small electric air pump to engage the left drive shaft, not vacuum.
Wouldn't a disengaging driveshaft be a better solution than the locking hubs?  Then you wouldn't have to get out and lock them.
I was told by the dealer that the diffs were completely different between the auto and manual trans Grand Vitaras.  In my manual both the front and rear look like they have 10 bolt carriers.  Are there any differences in the rear?
Thanks,
Marc
Offline gv1600
  • 83
« Reply #28 on: February 10, 2006, 06:47:55 AM »
     Kevin
I already have manual hubs on.
Superwinch hubs included with the calmini lift kit.
Offline the_maplebar
  • 466
« Reply #29 on: February 10, 2006, 08:28:46 AM »
They are completely different.  The manual has a steel diff, the auto has a tin can ;).  Other than that, they bolt right up the same.
