front locker questions
  • 29 Replies
  • 8113 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« on: January 30, 2006, 01:36:27 PM »
Can I use a  front 26 spline carrier and install a lockrite, or do I have to get a Sammy rear carrier and have it machined to accept the right axle? I'm going to a steel front housing/3rd member and Hagans widening and I figure while it's apart I might as well lock it up. I guess in a nut shell what i'm asking is do I have to get a sammy carrier or not?
    Thanks,
     Kevin
Re: front locker questions
« Reply #1 on: January 30, 2006, 01:41:52 PM »
I thought with the smaller front diff, you use a Sammy
locker, but the Tracker 26 spline diff has only 2
cross pins, the rear Sammy has 4 I thought it was
a strength issue.
I haven't installed one of these, but I was thinking
about it
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #2 on: January 30, 2006, 02:34:36 PM »
I don't think they actually sell a front lockrite for the kick but since you use your own sidegears does it matter? ???
      Kevin
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #3 on: January 30, 2006, 02:41:17 PM »
The lockrite locker that u use is for a Sammy rear diff so you need the carrier and the sidegears. The sammy carrier does have a 4 pin setup and is stronger. To machine the carrier can be done on a lathe in a couple of minutes.
Bill
« Reply #4 on: January 30, 2006, 03:20:30 PM »
Trail Tough sells a locker for Kick front . . .
http://www.trailtough.com/sidekick.htm
« Last Edit: January 30, 2006, 03:22:22 PM by LilRed »
Offline 87kevurai
  • 18
« Reply #5 on: January 30, 2006, 05:59:05 PM »
what i did on my sammy (although it may differ from a sidekick)was weld the rear spider gears and left the front open, on my Toyota axels.  I know that there are lockrights for kicks at RRO
http://www.rocky-road.com/kickdrive.html
the link doesnt work but if you just type it in the adress bar it will come up and then just scroll down to the lockrights.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #6 on: January 31, 2006, 08:39:21 AM »
Are sammy side gears 26 spline?
« Reply #7 on: January 31, 2006, 08:45:03 AM »
Yes
Offline brlj
  • 512
    • Bills 93 Tracker
« Reply #8 on: January 31, 2006, 06:10:24 PM »
Yeah forgot about this!!!!!!!!!! Excellent price for what you get!!!!!
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #9 on: January 31, 2006, 06:30:59 PM »
This is the way Id go. For the price you cant go wrong. All set up and ready to go.
Mike
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #10 on: February 01, 2006, 08:57:26 AM »
How about the Trailtough Quality I've heard some good and bad. I am seriously thinking of using the trailtough locker. They said that it was all new and not part sammy/kick mix.
   Kevin
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #11 on: February 01, 2006, 01:48:53 PM »
It's still a Lockrite... just in a modified carrier.. I wouldn't see a problem with it.. I am thinking about this locker too.. not a bad price.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #12 on: February 01, 2006, 08:02:22 PM »
I had a talk with Hawk this morning and he mentioned something I forgot. If you do the samurai center section carrier with the locker and the samurai side gears with 5.12 gears you will also need a diff can to keep the cross pins in. the 5.83 gears are wider and partially cover the pins thus keeping them from flying out.  Hawk also can machine the samurai carrier for you if you have one or he has them.
Offline 1bigtracker
  • 3409
« Reply #13 on: February 01, 2006, 09:23:12 PM »
so the Trail tought locker is just a normal lockright with a machined sammy carrier for 300 bucks.  not bad if you can't find some one with a lathe.
Stu
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #14 on: February 02, 2006, 10:41:56 AM »
Stu, The trailtough locker is not a sammy carrier but a new designed carrier for this application.
    Kevin
