timing belt questions
  • 1718 Views
Offline 1lowgeo
  • 46
    • Outlandish Trends
« on: January 31, 2006, 07:55:08 PM »
im going to be changing my timing belt in the sidekick soon. what all should i change at that time? so far i got the waterpump, timing belt, drive belts,valve cover gasket, spark plug seals, cam seals, crank seals, distribitor seal(??),adjusting valves. thats all ive gotten prices for so far. are there any pieces such as tensioners or gears i should replace? im using all factory parts as i can get them just as cheap as aftermarket. thanks for your input.
Mike
1997 Geo Tracker GSI  4dr 4x2
1995 Suzuki Sidekick JLX 4dr 4x4
mudfkr
Re: timing belt questions
« Reply #1 on: February 01, 2006, 01:37:58 AM »
You should replace the tensioner too for what it's worth when you do the belt.
