buying a samurai
  • 16 Replies
  • 4847 Views
Offline thermal
  • 15
buying a samurai
« on: March 01, 2005, 03:11:35 PM »
hey, im new to 4wheeling, suzukis, and this forum. im checking out a couple samurais in my area this weekend and was wondering what problems to look for. one is basically stock which is preferable, but another is built up just the perfect amount and I'm really leaning towards that one so far. im just afraid of wheeling damage. are there any common problems with samurais that I should look for or ask the guy about? or maybe just any questions to ask, as i'm even new to buying a  car. sorry if these are dumb questions but i'm quite the rookie.
Offline zookaholic
  • 387
  • "asphalt was created so yuppies could go 4 wheelin
Re: buying a samurai
« Reply #1 on: March 01, 2005, 03:48:39 PM »
if it has for wheels and runs......your golden! ;)
1987 Samurai, neon green, 1.3 stocker, 6.4:1 trail tough tranfercase, spoa, warn 8000, 34" swampers
1988 samurai (project, on blocks)
Offline prairie_dog
  • 234
  • 85/413 tin top
« Reply #2 on: March 01, 2005, 07:16:47 PM »
 if it will pass a mechanical inspection or close buy it up and hammer down ;D ;D
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #3 on: March 01, 2005, 09:05:35 PM »
Samurai's are very easy to repair and common enough for cheap parts. So if there might be anything (allmost) wrong with it you could repair it with a decent wrench  ;D I'd say if you want it easy, go for the built one if you want to have fun wrenching go for the standard one  ;) good luck
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline thermal
  • 15
« Reply #4 on: March 02, 2005, 01:05:18 AM »
thanks for the input. the built one's (86) got 125k miles and the stock's (87) got 108k. how reliable are sammy engines? i always hear about old yotas and subarus lasting forever, and other makes that like to break down early. is there any rule of thumb for milage on a samurai when it starts going downhill fast? i definently want the majority of the little money i have going into making it a beast instead of keeping it running.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: March 02, 2005, 01:35:07 AM »
Well, while SOME Suzuki motors fail early (150,000 miles), most go well beyond that.  If you change the oil and filters on a regular basis, the things are like Timex watches - they take a lickin, and keep on tickin!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #6 on: March 02, 2005, 05:10:15 AM »
u can pick up another sami 1.3 for less than $200. or u can get an tracker 1.6 8 valve for around $500 shipped to ur front door. have u worked on cars before. repaires like brake pads, oil change, plugs and wires. if u can do these things then it want be hard to keep ur sammi in top running condition. when u offroad u r eventually going to break something. so get handy with wrenches sami parts r cheep its the labor at the shop that will eat into ur pocket.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline zookaholic
  • 387
« Reply #7 on: March 02, 2005, 09:23:03 AM »
ive rolled mine once an had it on its side, each time it started right up and continued on!!!!!!! ;D
Offline thermal
  • 15
« Reply #8 on: March 02, 2005, 12:03:37 PM »
how preferable are getting wider axles like toyotas on samurias? I heard the wheelbase is really narrow and tipping is a problem. does it get to the point where you feel you cant do as much because your afraid of rolling?
Offline zookaholic
  • 387
« Reply #9 on: March 02, 2005, 03:50:32 PM »
you can tip them if your being stupid on a trail, but all around driving its not to bad they dont really go that fast anyway! but if you want stability go toyota, its not eazy or cheap but it works great, also a thing u can do is get a wheel with a back spacing with wheel spacers that will help toooo!
« Reply #10 on: March 02, 2005, 06:05:22 PM »
Offline Natebert
  • 1098
« Reply #11 on: March 03, 2005, 02:42:03 AM »
I've seen stock Sammy's do a lot of crazy stuff, without being 'tippy'.  The 'roll-over prone' idea that a lot of people have about Suzukis is a myth and a fabrication of lies by some publisher.
If you want to learn more about it, do a search on here and I'm sure you see all of the threads related to it.
Good luck in your decision!
~Nate
Offline Ian
  • 50
    • Island Rock Crawlers
« Reply #12 on: March 03, 2005, 05:41:33 AM »
There is some good info in this thread for you.  The sammys are generally reliable and good little vehicles.
Check the vehicle out like any other used vehicle you would look at.  Common engine problems that you may find include carb problems which can be corrected with a rebuild kit and leaking oil from the distributor ( a really easy fix with an o-ring).  If you can, do a compression test on it.  Also take it out and try 4 wheel drive.  Pay attention to the clutch on the built sammy as they can overheat in a built truck and become glazed pretty easily.  Check for smooth shifting of the tcase, needing a new shifter sheet bushing is common.  Listen for noise in the tranny the bearings sometimes need replacement.
Now the biggest thing that I would be looking for besides general mechanical is the rust.  Check all of the floor boards particularily in the back.  Pull up the carpet if it has any.  Check the rear wheel wells behind the fender flares.  You will need to pull back the interior panel and look from the inside.  Check the front wheel wells behind the flares from inside the engine compartment.  The other spot to look is in the rockers but this is not easy to check without removing the plastic covers that are on them.
Hope this helps.
« Reply #13 on: March 04, 2005, 01:34:12 PM »
I thought that I would get more comments about that link than that  ???
« Reply #14 on: March 04, 2005, 02:52:30 PM »
Theres probley not much more that can be said. ;D
