I need help on a tranny question.
  • 1883 Views
Offline Mythose
  • 361
« on: February 01, 2006, 02:58:19 PM »
Ok the moron that had my kik before me " yes moron  he drilled a hole through the head into the block and used a 3/4 inch piece of all thread instead of a head bolt"   FYI  it has a newer rebuilt motor.   any back to the question the afor mentioned moron striped the tranny drain plugs, not the threads, the part that the 3/8ths ratchet goes into.    I talked to a cupple of trany places and
its going to range from 50 to 200 bucks to have them take it out ----- one of the tranny places told me that i should just take a cold chisel and hammer and use that to unscrew the pluge and just replace it with a new one.
what do you guys think?
Offline takai
  • 907
Re: I need help on a tranny question.
« Reply #1 on: February 01, 2006, 03:16:01 PM »
If you are really careful you might be able to get that plug out that way. I have friend over here that is an absolute master at that. Me...I break my hand open on the case after running the cold chisel through my other hand.  ;D
'Cause, I am to misbehave.
Offline Skeeter
  • 23
« Reply #2 on: February 01, 2006, 03:44:58 PM »
Cold chisel & hammer should get you out of trouble.
« Reply #3 on: February 01, 2006, 07:00:53 PM »
You could drill a hole in the center and
use a big screw extractor to back it out.
Offline Mythose
  • 361
« Reply #4 on: February 01, 2006, 10:12:31 PM »
I was thinking of a bolt extractor so i think what i will do is invest the 90 bucks into a good chisel set and bolt extractor set,  and a case of beer to bribe my buddy with a lift,  and spend an evening to get the bolt out seeing as chisels and extractors are things that you ALWAYS need
thank you and as always the imput is awsome.
« Reply #5 on: February 01, 2006, 11:02:51 PM »
You could just weld a long bolt to it and then just use a wrench on it!
