Trans swapping
  • 1594 Views
Trans swapping
« on: February 04, 2006, 10:36:36 AM »
 ??? Can I use the 5 speed manual trans out of my 92 Tracker parts trucklet, in my 95 that currently has an auto? Would I have to change ECU's? Just thinking for future use in case I use up the auto. Also, with the manual, would I have a lower 1st gear than the auto?  Thanks
Re: Trans swapping
« Reply #1 on: February 04, 2006, 12:12:20 PM »
You could make the change, lots of work
if you swap ECUs you need to swap the
whole harness to be sure
Re: Trans swapping
« Reply #2 on: February 05, 2006, 05:08:08 PM »
Damn1 that sounds like a PITA! Maybe I'll just see if I can swap parts at a salvage yard instead. Besides, the auto is so much easier to trail with. Thanks Wild.
Offline Wildweasel
  • 106
  • Git er Done!
    • Wildweasel's world
Re: Trans swapping
« Reply #3 on: February 05, 2006, 06:53:34 PM »
You can swap them, you will also need the clutch pedels and such.  the ecu issue- with a 95 it is a non-Obd2 system so it may be a non-issue.   you should also check to make sure your driveshafts will work too. (lenght wise)  Just some thoughts. I went the other way on my last rig. from an auto to man.
Glenn
91 geo tracker, Toyota axles, twin tcases,35's too many mods to list.
