92 samurai blowing taillight fuse
  • 1733 Views
Offline lovede
« on: February 05, 2006, 10:50:05 AM »
   I have a 92 blowing the fuse for the taillight.  I don' t have a good wiriing diagram with the correct wire colors so it has been very hard to trace.  Any help appreciated.  Is this a common problem that someone has had before?
Offline hobgoblin
  • 224
Re: 92 samurai blowing taillight fuse
« Reply #1 on: February 05, 2006, 07:01:39 PM »
Hello,
Haynes repair manual has the diagram on page 12-31....If you gave more info may-be I can look at book and walk you threw it???May-be.....
Tom K.
Offline RJkick
  • 634
« Reply #2 on: February 06, 2006, 01:44:42 PM »
Have you replaced the tail light bulbs
I had a similar issue that the fuse was fine until I put the kick in reverse and then the fuse would blow.  Both tail lights worked but apparently not optimally because I had to replace one to fix the problem
hope that's yours as well
« Reply #3 on: February 06, 2006, 10:50:50 PM »
Do you have a cheap round four pin trailer plug socket on it? look inside for rust.
