Sidekicks not kickin, please help.
  • 2349 Views
Offline zoomzoom
  • 58
  • Long Live the ZUKI!!!
« on: February 05, 2006, 08:28:44 PM »
I have a 92 sidekick, 2 door, manual, and i was wheelin it around on some rocks, got out to take a pic, and it just died. i thought it ran out of gas so i put some in it and its still not running. if you spray starting fluid in the intake it kicks right over but shortly dies.
I came back a day later and tried it and it fired up and ran for about 30 seconds and then died again. the fuel relay is clicking on and fuel is pumpin to the throttle body but im not getting nothin. is it an injector, computor, ??????, thanks  a lot, lance
91 Kick-2" suspension-Custom ford wheels(cut out)-4.24 transfer case-31's-homemade rear bumper-Home fixed ECM-
Re: Sidekicks not kickin, please help.
« Reply #1 on: February 05, 2006, 08:57:22 PM »
I have heard of computers doing this,
don't know if they restart and stop again tho
Offline Sidetracker
  • 30
« Reply #2 on: February 06, 2006, 06:11:12 AM »
I had the same problem.  I changed the ecm and it started up and ran for about two weeks.  Now, as I was driving home from work on Saturday it stopped running again.  This time there is no pusleing noise at all, nothing, it won't start.  So I put the old ecm back in and it makes the all the same noise and still won't start.  I changed back to the other ecm and it starts and runs for about 3 seconds and then won't start.  Am I that unlucky to have two bad ecm's or is there something else causing this.
Offline wedge
  • 38
« Reply #3 on: February 06, 2006, 04:19:09 PM »
check your fuel pump, and make sure your getting gas.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #4 on: February 06, 2006, 04:34:18 PM »
it is very possible to have 2 bad ECM's - if your trackick was born anywhere from 90-93 the ECM's are known to have inferior capacitors(3 of them). Have them changed and you should be good to go. If you search "ECM" you will find lots of people complaining about the same problem.
FWIW - also check the wire harness connector behind the driver side tail light for corrosion, these are known to go bad too - the large pink wire is for the fuel pump.
« Last Edit: February 06, 2006, 04:37:03 PM by Uncivilized »
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #5 on: February 06, 2006, 04:36:10 PM »
It's not getting fuel because of the ECM, it controls the pump.
Offline zoomzoom
  • 58
« Reply #6 on: February 06, 2006, 08:35:49 PM »
thanks guys. i have taken the ecm appart and found the 2 bad capacitors but im going to change all 3. if it works ill let you know. i bought a pack of them so ill have some to pass out. thanks, lance
