Dim Front Headlight??
  • 2707 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
« on: February 06, 2006, 08:41:21 AM »
For the past 8 months my front passenger side head light has been a bit dimer than the driverside, and now I have somtime this week to fix it (finally). But my quetions are, is it common? because i see alot of sidekicks with one headlight brighter than the other.  The other quetion is, is it easy to fix?? Because i dont want to poke around and start blowing fuses. ::) Please Help me, cuz its really starting to bug me.
Thanx.
« Last Edit: February 06, 2006, 08:48:32 AM by SunrunnerGT »
Sunrunner GT, Gold Trim Level
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
Re: Dim Front Headlight??
« Reply #1 on: February 06, 2006, 09:22:21 AM »
have you tried replacing both bulbs yet?? as a halogen lamp gets older it gets dimmer
thats the first thing id try because that is the easiest. you can replace them with aftermarket brighter ones if you wish. (do a search for the different ppls oppinions on the different brands hopefully this wont turn into another one of those threads)
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #2 on: February 06, 2006, 09:31:22 AM »
I just replaced them in the summer. and there's no diff
  • 264
    • Cardomain site
« Reply #3 on: February 06, 2006, 09:51:50 AM »
have you tried to have them aimed? if one is off it will apear dimmer
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
« Reply #4 on: February 06, 2006, 10:16:47 AM »
really... i never thought of that ::)
Shilly
« Reply #5 on: February 06, 2006, 06:31:08 PM »
Start poking around and look for a corroded ground wire, and gently tug on the connectors for the bulb socket while you're in there.  Are you having any weird blinker or brakelight problems, too? If so, that is more evidence of a partial ground.  Good luck; hope this helps...
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #6 on: February 07, 2006, 02:21:55 AM »
i just replaced both headlight fuses in the fuse panel under the dash. this has happened to me a couple of times.
maybe try that. if the fuse keeps blowing,  then you have a bad wire somwhere, either not grounding, or shorting out.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #7 on: February 07, 2006, 08:03:39 PM »
*****Switch the bulbs out from one side to the other and see what difference it makes*****
This has happened to me a few times and i have dived deep into it trying to figure it out, when it was always just a bad bulb.
Switch the 2 around, it won't cost you anything and see if it is then dimmer on the other side.  If it is, it's a bad bulb with a weak connection.
I put a new bulb into my tracker once and it was really dim and it took forever for me to figure out that it was just defective and the connections of the wires inside the actual bulb were not very strong.
1993 4-door Sidekick
4.24:1 t-case
