Front axel locking nuts?
  • 10 Replies
  • 3548 Views
Offline Mythose
  • 361
« on: June 27, 2005, 03:21:04 AM »
Ok went to do my wheel bearings, got the hubs off and the bearing locking plate? why they need this i duno, any way the lock nut on my front axel os completly round, with 4 evenly spaced holes in it, WTF.  and were does one aquire one of these wrenches? i am going to go to Lesswab today and lookinto buying a wrench, but this is strange no? ??? ???
Re: Front axel locking nuts?
« Reply #1 on: June 27, 2005, 03:41:14 AM »
No, you need to remove the 4 little screws
that hold this plate to the bearing nut, this
round thing keeps the preload from backing
off of the bearings.
Unless you are farther in than I think then
a little tap with a cold chisel and hammer
should do the trick
Good Luck
« Last Edit: June 27, 2005, 03:42:35 AM by wildgoody »
Offline Mythose
  • 361
« Reply #2 on: June 27, 2005, 03:53:31 AM »
Yeah i took out the 4 little screws, and took off the plate, and that round thing i smacked it a few times with a hamer and chisel pretty good and it did not budge, it has lots of threaded holes and then that ones that are not threaded, i took a bolt and set it in the hole that was threaded and smacked it until I cut the bolt in half with the cold chisle!
its on  there boy I tell ya what.
any other thoughs, or is this the proper aplication if a friends hand an a sledge hammer? ;D  LOL
i hope you catch the meaning. do i just need a BFH?
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: June 27, 2005, 03:56:46 AM »
You can beat them off, it's getting them back on thats the problem.
They torque down to around 50 ft. lbs.
32 MTR's Warn 8000i
« Reply #4 on: June 27, 2005, 04:03:19 AM »
Use a blunt cold chisel so it
doesn't cut the nut, I don't think
they are left hand thread, but
make sure you are not tightening it
If that doesn't work, I guess it's off
to get a socket that fits, it's the propper
way, but I hate to buy all those special
tools that a hammer and chisel works
fine on
Good Luck
Offline Mythose
  • 361
« Reply #5 on: June 27, 2005, 04:12:14 AM »
My thoughts exactly, When I did the axels on the sub, the wrench 1 1/2 inch box end 96.00  :o  2" socket for upper ball 60.00 :o adapter for 1/2" drive to 3/4" drive 12.00  :o :o
4 foot breaker bar for above mentioned 70.00 I mean holy ______ !!!!!  >:(
so now I have all the tools that i will never use again, and to mention all the bolts had to be torqued to or over 100lb
Offline chet
  • 556
  • Zuki time!
« Reply #6 on: June 27, 2005, 04:53:10 AM »
You have to really smack them to break them loose. Getting them tight again is tricky also. If I have to do it again I am going to make a tool
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #7 on: June 27, 2005, 08:40:47 AM »
Have you checked a local tool rental place?
A lot of Auto Parts stores wil also rent you tools for cheap or even free.  Advance Auto and O'Reilly's come to mind...
Ack
Offline LawDog
  • 531
    • Emerling Chevrolet
« Reply #8 on: June 27, 2005, 10:17:12 AM »
Raiding my old man's tool box...Priceless 8)
Offline Whipp
  • 62
« Reply #9 on: June 27, 2005, 11:48:07 AM »
Hawk Suzuki will rent them.  I can't remember the rate, I don't think it was too much.  I just ended up buying the socket.
- Craig
1989 Sidekick with 3" Calmini suspension, Old Man Emu Struts, Calmini header and exhaust combo, A/C on board air.
- Sold to my brother!
Offline Mythose
  • 361
« Reply #10 on: June 28, 2005, 09:22:00 AM »
LOL i miss the shope haveing all the tools for fabrication back in NC.
