99 vitara differential slipping
  • 1595 Views
Offline chard
« on: February 08, 2006, 12:48:31 PM »
i have yet to find out what the real problem is with the front diff. I sounds like it skips a tooth with a big clunk noise. Does any one know?
Offline the_maplebar
  • 466
Re: 99 vitara differential slipping
« Reply #1 on: February 08, 2006, 02:00:12 PM »
Welcome to Zukiworld.
I haven't had any problems like this with mine.  It would probably help if you explained your problem a little better.  Does it happen when you are engaging 4wd, all the time, only at certain speeds etc.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #2 on: February 08, 2006, 02:24:24 PM »
Sounds like you have a broken ring or pinion... or spider gear in the front diff..
I would make sure it isn't your CV's though....
