Ford wheels
  • 1578 Views
Offline zoomzoom
  • 58
  • Long Live the ZUKI!!!
Ford wheels
« on: February 08, 2006, 07:09:21 PM »
Is the backspacing on the stock ford 15x8 wheels, off a newer bronco, fit on a sidekick? or do things need to be modified. if not what would be your first choice for some junkyard junkers. thanks,
lance
91 Kick-2" suspension-Custom ford wheels(cut out)-4.24 transfer case-31's-homemade rear bumper-Home fixed ECM-
Offline bus_driver
  • 479
  • the voices tell me different things
Re: Ford wheels
« Reply #1 on: February 08, 2006, 07:14:17 PM »
same Q here ? looking for junkyared rims also.
92 2dr soft top
2-1/4" cherry bomb exhaust
235/75/15
2 inch lift
custom mud
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Ford wheels
« Reply #2 on: February 08, 2006, 07:22:30 PM »
I'm not sure about newer Ford wheels...
However, I have a set of full-sized Bronco wheels on my '88 Samurai shod with 30 x 9 BFG ATs and they work nicely.  No rubbing with stock axle and a RUF kit re-centered for a stock wheelbase.  Pretty generic SPOA setup.
These are aftermarket chrome spoked wheels from, I think, the early 80s that I snagged for $40.00 for a set of 4 at a salvage yard.  Exact center hole fit.  Not sure what the backspace is...
Ack
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: Ford wheels
« Reply #3 on: February 09, 2006, 04:07:01 AM »
Do a search, there's several topics about this if you just look. That said, my first choice to look for would be 80's full size Bronco rims or rims off early broncos. Ones with big center holes, because they also had rims with small center holes that wont fit. The rims are usually around 3.5" to 3.75" of backspacing and work perfectly on Track/kicks...
