Tow straps
  • 2560 Views
Offline echojeff
  • 414
  • Lo que sea
Tow straps
« on: February 09, 2006, 09:12:16 PM »
So I like to shop for the best deal because I am cheap.  4Wheel parts has tow straps, 20,000lb rated for $25-$30 .  Harbor freight has a sale, 8500lb rated for $10.  So the zuk is less than 3000lbs, so why do I need a 20,000 lb strap? You need to buy shackels to use the ones from 4Wheel parts also.
Jeff
95 Kick 4dr JLX.
Re: Tow straps
« Reply #1 on: February 09, 2006, 09:15:43 PM »
If you are stuck good, it could take more than
3000 Lbs to get you out, might take 10,000
Re: Tow straps
« Reply #2 on: February 09, 2006, 10:23:19 PM »
Don't ever use a strap that has the built in hooks on it period.
Re: Tow straps
« Reply #3 on: February 09, 2006, 11:03:31 PM »
Yes, Bigger is Better.
Don't buy one from Wally World.
Buy a real Recovery Strap.
Cheap ones do break.
This is where you get "what you pay for".
Offline echojeff
  • 414
  • Lo que sea
Re: Tow straps
« Reply #4 on: February 10, 2006, 04:49:45 AM »
Ok I get it now ...
Tow strap = tow down the road.
Recovery strap = rescue your ars out of the jaws of the earth!  ;D  (and not fail trying)
Jeff
95 Kick 4dr JLX.
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: Tow straps
« Reply #5 on: February 10, 2006, 06:54:10 AM »
Ok I get it now ...
Jeff
The reality is that most "tow straps" are what is considered a static strap. What that means is there is no elasticity in it and it is like pulling with a wire cable. Too much tension and it will snap and become a projectile and could possibly hit and kill someone. On the other hand, A good recovery strap has some elasticity to it so when you pull it stretches some and then snatches the stuck truck out. Make sense?
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Tow straps
« Reply #6 on: February 10, 2006, 07:25:57 AM »
matter of fact, we called them "snatch straps" my whole life..
Buy a GOOD one.. best you can afford.. it will last a lifetime with proper care..  a cheap one will just at best leave you stuck, at worst kill someone..
I like the new super strap dealies, with the "weave" pockets for fastening them.. they are bit bit pricey, but look great.  I want one
Offline AJMBLAZER
  • 2166
  • Your mom.
Re: Tow straps
« Reply #7 on: February 10, 2006, 01:22:04 PM »
This is where I get mine.
http://www.aaasling.net/
I also have to agree with the fact that a strap with any metal hooks, chains, or whatever on the ends is BAD.  Doesn't matter the purpose or use of a strap, if there's heavy metal at the end it becomes a projectile if the strap or mounting point on the vehicle breaks.
Offline crikeymike
  • 713
    • http://www.wazuks.com
Re: Tow straps
« Reply #8 on: February 10, 2006, 02:47:12 PM »
I use an ARB snatch strap.  It's rated to 17,500lbs and has a 20% stretch.  It enabled my sidekick to pull a 72 Wagonner bogged front and rear pumpkins in the mud out of a hole this past sunday.  3000lb suzuki tugging a 5000lb waggy (which was pretty badly stuck) and getting him out makes me pretty satisfied with the strap.  I've always loved the "bungee" effect of a snatch strap, and it's cool how my kick will squirm sideways when pulling hard on something.
(later on the same day i pulled out a toyota from the same bog, but different location, with no effort, but i got bragging rights on him anyway).
1993 4-door Sidekick
4.24:1 t-case
