New Samurai Suspension Installed
  • 11 Replies
  • 3487 Views
Offline rkteckt
  • 214
« on: February 11, 2006, 07:36:37 PM »
I wont bother going into how bad my last suspension was, but this new one is a RRO jp-eater extreme spring under with old man emu springs. Much better.
Any advice on what to do about the rust already appearing on the shackles?
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
Re: New Samurai Suspension Installed
« Reply #1 on: February 12, 2006, 06:44:44 AM »
nice lookin setup.  I could be wrong, but it looks like your fron shackles are on backwards.  I'm pretty sure they should be angled in toward the axle, not away.
Offline rkteckt
  • 214
« Reply #2 on: February 12, 2006, 08:16:06 AM »
Yeah they are on backwards, the installer didnt use the directions for the easy stuff he said.  I looked at it for a while but the geometry doesnt seem to be different with the shackles backwards so i will just leave it for now.
2005 Avalanche Z71
2003 Matrix XRS
Offline takai
  • 907
« Reply #3 on: February 12, 2006, 08:21:13 AM »
That is the suspension that will be going on my Samurai...when I can afford it.  ;D
'Cause, I am to misbehave.
Offline rkteckt
  • 214
« Reply #4 on: February 12, 2006, 08:46:46 AM »
Its a nice set up,
My total cost was 1000 for the kit, 40 bucks for perches 150 for the shocks, and about 700 to the installer. so right around 1900 bucks.
Thats the price i pay for being a house fixer-upper-guy  not a car fixer-upper-guy
2005 Avalanche Z71
2003 Matrix XRS
Jayzuki
« Reply #5 on: February 12, 2006, 05:16:24 PM »
That looks really nice, excellent set-up!!
  • 265
« Reply #6 on: February 13, 2006, 08:51:08 AM »
OK, I just figured you may hit the shakles on the bumper at full flex, but without a SPOA lift I'd doubt it.  BTW, what kind of tires are those (Brand, model and size)  Got any pics of it flexed out?  I always wondered how a sprung under YJ-leafed sammy would do.
Offline blasterfan
  • 54
  • SHEAAAAA
« Reply #7 on: February 13, 2006, 03:31:35 PM »
how much lift do you got in total? what size tires?
looks sweet , i hope mine will look the same when its done this weekend
85 tin top: spoa, weber, thourly, mud kings, no rust, shackels bumpers
88.5 soft top: spoa, lift springs, shackels, 1.6L, hybrid real axle, yota drivshafts, 5:13 gears, bumpers, winch, rear rad, 5 points and buckets, ltbs, lockers, custom exhaust, some trail scars and alot of army green paint
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
« Reply #8 on: February 14, 2006, 01:47:50 PM »
  Next time you need something done on your sammy let me know. Im right up the hill from you, and i could probably save you some money on labor cost or trade for some work on the house.
If its not broken, break it
Offline rkteckt
  • 214
« Reply #9 on: February 15, 2006, 08:30:37 PM »
The tires are Gateway Buckshot wide mudders at about 30 inches in diameter.
It will be a while before i have any flex pics, have to cut off the old bumper mount tubes and move my brake lines first. The old brake lines were welded to these wierd drop tabs about 5 inches lower than normal so the fabricator didnt need to get longer lines.....wasnt a problem with the old non flaxible suspension, but with the YJ springs the top of axle perches hit the brake line tabs pretty quick.  I have a big old pile of dirt in the back yard , and i got pretty good flex up until the perches hit the brake tabs though.
I do know that when you put 300 punds of concrete bags in the back that the ride quality is great.....:-)
RRO says this set up gives about 5 inches of lift, 2" shackles and 3" springs i guess. The front seems a little bit higher than the rear for some reason, but if i ever get a plow mounted i guess it will even it all out.
Thanks for the offer, I actually had lots of offers from my employees to do the work, but my insurance agent wanted the work done somewhere with Liability insurance.
2005 Avalanche Z71
2003 Matrix XRS
Offline r3cc0s
  • 321
« Reply #10 on: February 16, 2006, 08:29:55 AM »
if you don't mind me asking, what kind of tires are those? I don't think I've seen a swamper replicaa like those... or are they swampers?
Offline rkteckt
  • 214
« Reply #11 on: February 17, 2006, 03:51:52 PM »
2005 Avalanche Z71
2003 Matrix XRS
