4K rpm cutout
4K rpm cutout
wedge
38
I Love ZUKIWORLD!
4K rpm cutout
February 15, 2006, 01:34:11 PM »
Ok, I just replaced the oil pump on my 89 sidekick, and now it drives ok, but at 4k rpm, the engine cuts out like i hit the revlimiter.
Not really sure where to begin troubleshooting this, thnaks guys
Ken
reb
195
Victim of CRS--Can't Remember Anything.
Re: 4K rpm cutout
February 15, 2006, 03:38:38 PM »
My guess is the oil pump is not related to the problem. How is your fuel filter?
wedge
38
I Love ZUKIWORLD!
Re: 4K rpm cutout
February 15, 2006, 09:06:51 PM »
no clue, I'll try that, but its a distinct cutout, in any gear, or even in neutral. revs up to 4k fine, then the engine cuts and drops back down. The trucklet sat for a week and a half while I did the oilpump/installed diggers spacers/cleaned radiator/replaced fan clutch. Non of which should cause this. could it be the timing belt off a tooth?
any other ideas?
wedge
38
I Love ZUKIWORLD!
Re: 4K rpm cutout
Reply #3 on:
February 16, 2006, 03:09:49 PM »
found the issue, the timing belt was off by one notch. must have misaligned my match marks when I reassembled it. Got it half way back together after adjusting the belt, but only had 30 minutes to work on it today before I go to work.
Rhinoman
4502
36
Bend it, Break it, Fix it
Re: 4K rpm cutout
Reply #4 on:
February 17, 2006, 12:04:32 AM »
How well did it pull before it cut out?
http://www.rhinopower.org
wedge
38
I Love ZUKIWORLD!
Re: 4K rpm cutout
Reply #5 on:
February 17, 2006, 12:13:52 AM »
very weakly, I could drive it, but not well.  then it would cut out like the ignition was interupted, and when the rpm came back down it would run better.  But it didn't set off any check engine lights
Rhinoman
4502
36
Re: 4K rpm cutout
Reply #6 on:
February 17, 2006, 02:47:54 PM »
OK, I was thinking it should have pulled stronger but I guess the ignition timing was out too
da_tub
307
oops...can we still back up>?
Re: 4K rpm cutout
Reply #7 on:
February 17, 2006, 10:47:57 PM »
was it one tooth advanced or retarded?? zaggy was telling praire and myself. one tooth advance would kinda wake her up a bit...
91 four door ,and some stuff
wildgoody
8134
67
Re: 4K rpm cutout
Reply #8 on:
February 18, 2006, 12:21:12 AM »
Not without re-setting the timing,
get these little engines retarded in
the timing and they run slugish, just
a few degrees makes a big difference
wedge
38
I Love ZUKIWORLD!
Re: 4K rpm cutout
Reply #9 on:
February 18, 2006, 03:56:11 AM »
it was retarded one tooth, just like me for putting it back together off
wildgoody
8134
67
Re: 4K rpm cutout
Reply #10 on:
February 18, 2006, 09:14:42 AM »
Had you re-set the ignition timing
it would have run fine, in fact a little
stronger on the top end RPM, but the
timing was retarder with the cam, and
made it a dog
Sorry you had to do all that extra work
for a timing problem
wedge
38
I Love ZUKIWORLD!
Re: 4K rpm cutout
Reply #11 on:
February 18, 2006, 07:00:13 PM »
its not that bad, I don't have any extras like power steering or AC, so it only took an hour and a half or so to figure out the problem and fix it. That and air tools help.
