6.4:1 tcase gears
  • 2412 Views
Offline mlovetripp0
  • 204
  • do more with less
6.4:1 tcase gears
« on: February 18, 2006, 08:31:54 AM »
has anyone installed this set into there sami case? if so is there any thing wrong with this gear set?
87 sammi
Offline takai
  • 907
Re: 6.4:1 tcase gears
« Reply #1 on: February 18, 2006, 09:01:14 AM »
What size tires and gears are you mating it with?
'Cause, I am to misbehave.
Offline mlovetripp0
  • 204
  • do more with less
« Reply #2 on: February 18, 2006, 09:05:06 AM »
right now i have 31 and a stock sami gear i think 3.90:1 r&p
87 sammi
Offline takai
  • 907
« Reply #3 on: February 18, 2006, 09:11:42 AM »
I believe that the 6.4:1 case is supposed to be perfect for 31" - 33" tires. I still run a 4:1 but am still running stock tires. I haven't heard anything bad about this set up as of yet. Just get ready to pull steeper hills off road and higher rpms out on the open road.  ;D
Offline mlovetripp0
  • 204
  • do more with less
« Reply #4 on: February 18, 2006, 09:17:54 AM »
waiting for trail tough to send it to me.would i need a bigger t case support? and where can i get the tranny specs for my sami?
87 sammi
Offline takai
  • 907
« Reply #5 on: February 18, 2006, 02:16:57 PM »
Your case will be the same. You could use factory mounts but, since you put that much money into your case I would protect the investment. Take a look at TT's Mighty Kong T-case mount.  I am saving for one at the moment. As for specs, I could probably dig up the ones for my tranny but, you listed your gearing as 3.90 which means that you have a late model Sami. You have a different set of tranny ratios. I am sure that you could find them on the web...somewhere.
Anybody else know?
« Reply #6 on: February 18, 2006, 11:46:00 PM »
I just put one in mine from t.t., they are a strong gear set but if you do abuse them the weakest link is the input gear, it is alot smaller than stock but it is a higher quality material,I love mine it will climb a tree, you will need a kong mount and re weld the long arm on your frame they are only spot welded, I tore mine loose the first day but I caught it in time no damage, t.t has a new rubber/polly type mount out for the long arm also, it takes a while to put them in I had to grind the case in five places, download the instuctions from petroworks, they have pictures and specs.   have fun.  ;D
Offline mlovetripp0
  • 204
  • do more with less
« Reply #7 on: February 19, 2006, 12:49:02 AM »
thx for all the help
« Last Edit: February 19, 2006, 12:51:37 AM by mlovetripp0 »
87 sammi
