Best Camshaft
  • 24 Replies
  • 9482 Views
Offline ningram1
  • 84
  • 92 Tintop Vitara
Best Camshaft
« on: February 20, 2006, 10:54:00 AM »
Hi all
I got the money together for a new cam and gas flow job on the spare cylinder head I've got ;D
I'm looking for low and mid range power
what camshaft do people recommend?
Thanks
Nick
Chaos, Panic, Disorder. My work here is done.
Re: Best Camshaft
« Reply #1 on: February 20, 2006, 11:17:01 AM »
8 Valve or 16 Valve ?
Any cam is an improvement,
Hawks has a 16V cam that
should work well for you.
Offline cj
  • 1276
  • I drive a really big ATV
Re: Best Camshaft
« Reply #2 on: February 20, 2006, 11:46:34 AM »
Aw c'mon Wild I expect more from you like..........TURBO it.
 ;D
Re: Best Camshaft
« Reply #3 on: February 20, 2006, 12:01:37 PM »
At least he could show us how to grind the back side of the cam with a 4" black and decker grinder  ;D
Re: Best Camshaft
« Reply #4 on: February 20, 2006, 04:32:33 PM »
I have a smog legal 8V cam, had it
custom ground before performance
parts were available, noticeable
improvment over stock.  Cost me 4
hours drive and $200, but I'll get
you a custom ground cam for $30,
I'll use my 4" angle grinder    ;D
Offline cj
  • 1276
Re: Best Camshaft
« Reply #5 on: February 20, 2006, 04:40:15 PM »
 ;D
Offline takai
  • 907
Re: Best Camshaft
« Reply #6 on: February 20, 2006, 05:28:51 PM »
What lift and duration?  ;)
'Cause, I am to misbehave.
Re: Best Camshaft
« Reply #7 on: February 20, 2006, 09:43:18 PM »
Lots of both  :)
Offline ningram1
  • 84
  • 92 Tintop Vitara
Re: Best Camshaft
« Reply #8 on: February 21, 2006, 04:40:46 AM »
D'oh ::) should have said
92 Vitara 8 valve single point injection
I'm in the UK, was thinking of the Calmini cam, but if there's a better one out there....
Ta
Nick
Offline ningram1
  • 84
  • 92 Tintop Vitara
Re: Best Camshaft
« Reply #9 on: February 24, 2006, 04:11:54 AM »
No One got any opinions on this then? ???
Nick
Offline zaggy
  • 1134
Re: Best Camshaft
« Reply #10 on: February 24, 2006, 08:38:54 AM »
Things to watch on cam selection (In my opinion)
RULE OF THUMB
Where do you want your power?
The stock cam (by memory) in your engine is 200 degrees duration and .350" lift
If you want more power up higher then you will need more duration...ie: 220 degrees
If you want more power down lower then you need less duration...ie: 180-190 degrees
More lift is a gain but lots of lift can be tough on the valve train (found out the hard way)
I would not exceed .395"
As a rule of thumb there are always exceptions but over the years I have found it to be 90% correct. (My experience).
Post more detailed engine specs (got a header or other mods?) with where you want your power and the kind of gains you are looking for and maybe myself or others can be more exact.
Zag
Offline Yoak
  • 577
Re: Best Camshaft
« Reply #11 on: February 24, 2006, 09:15:42 PM »
I had a cam from calmini...
It was to long....
Took it back to them and the ground off the difference on the gear...
After that everything matched up....
But the engine ended up dieing a few months later...
Im not sure if the cam did ir or not...but I bent a rod....
Got an engine from asianauto....with his custom cam, seems a bit more perky....
(still going to swap in a 16v though)
Offline ningram1
  • 84
  • 92 Tintop Vitara
Re: Best Camshaft
« Reply #12 on: February 26, 2006, 02:51:23 AM »
Zag
Engine is stock - I run a K & N flat panel filter, and I have a 4 bracnh manifold (think you call them headers).
I have 5.83 R & Ps, otherwise stock transmission, and with 33" Goodyear MTRs the gearing is back to stock (checked on GPS).
It's just about liveable with, both on and of road. But in the summer when I want to tow my folding camper it will be a PITA.
I reckon I have a choice - either sammy t case swap, or get more power from the motor. A friend has just done the t case swap, he has gone back to stock R & Ps, he runs 32" tyres and is running at 4k rpm at 60. So if I do the same swap I would also have to go back to standard R & Ps... trouble is I have a shoulder injury so would have to pay someone to do all of the above.
Other option - find more power form the motor. I have a spare cylinder head, that's in better condition than the one on the truck at the moment, and have found a cylinder head specialist near home, so I thought if I can get more torque between 2 and 4k RPMs that will help when lugging the camper.
I reckon a cam tuned for more torque and gas flow job would do the trick?
Yoak thanks for the info on the calmini cam, think I will drop Hawk a line...
Cheers
Nick
Offline wezzlegod
  • 227
  • under construction crowler
Re: Best Camshaft
« Reply #13 on: February 26, 2006, 04:32:17 PM »
Zag
Cheers
Nick
do the trany case swap and ill treid you r&ps. mine a little cash for yours.
Offline zaggy
  • 1134
Re: Best Camshaft
« Reply #14 on: February 26, 2006, 05:50:53 PM »
Hello again
     All the info you gave was great, missing one thing though!
Where do you want your power.
Think of the cam sorta like the engines brain, it tells the rest of the engine at what rpm the peak hp and torque are going to occur.
So YOU really need to get a handle on where you want your power increase to be.
Let me know and I will see if there is something I know of to help you out.
Zag
