Dies when stopping
  • 20 Replies
  • 9600 Views
Re: Dies when stopping
« Reply #15 on: May 17, 2006, 04:57:02 AM »
I think the problem is the timing advance. Is there a way to lock it out & just set it at 35 degs?
Does anyone know which wire on the distributor or VSS controls the advance?
There isn't a single wire that controls the advance. Its calculated by the ECU based on information on RPM, manifold pressure (unless you have a seperate vacuum advance), water temperature and air temperature. On OBDI models you can put a jumper across the diagnostic terminal to fix the ignition timing.
« Reply #16 on: May 17, 2006, 11:05:21 AM »
I was looking the FSM. A fault with the idle switch does not set the Check Engine Light, you have to pull the codes. I also know that on some Mitsubishi ECUs the same applies to the VSS, however the FSM indicates that this is not the case on a Zuk.
Offline Zimo
  • ASE certified mechanic
« Reply #17 on: May 17, 2006, 01:49:25 PM »
That's the info I needed - thx...Can you tell me which wire it is? I have a '95 16 valve "California" model Geo Tracker, vin code 6.
'95 Tracker.
Offline Zimo
« Reply #18 on: May 22, 2006, 04:15:18 PM »
FYI - I figured out the engine surge problem. Their was a vac leak at the EGR valve. I replaced the gasket & torqued it down, no more surge.
'95 Tracker.
Offline JayN
  • 220
« Reply #19 on: May 24, 2006, 02:17:02 PM »
i am having the same sort of problem with my 97 1.8L sport. it idles pretty slow and rough for a few seconds at stop. it is a auto tranny. i looked for the idle air adjustment screw but couldn't find it.
any body know how to solve the problem ont he 1.8L?
thanks
J
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
Offline JayN
  • 220
« Reply #20 on: July 19, 2007, 10:43:07 PM »
whats the fix for this ont eh 1.8L
mine is still doing it. is there a idle adjust screw ont eh 1.8?
1970 gmc truck
1950 dodge truck
1974 corolla
