Dies when stopping
  • 20 Replies
  • 9671 Views
Offline ArkansasTracker
  • 85
Dies when stopping
« on: February 24, 2006, 07:02:12 PM »
Had Autozone pull the code and it was something with the flow and an EGR code.  Replaced the EGR valve and it still idles poorly and even dies in the middle of a turn after slowing down from higher speeds.
Any ideas what to check next?  Autozone wasn't sure and I don't have a clue.
Thanks in advance,
Jerry
'96 Soft Top Geo Tracker, auto (leaking), coil spacers, 30X9.5 Mud Rovers
Offline ToyYoda
  • 226
Re: Dies when stopping
« Reply #1 on: February 24, 2006, 07:23:40 PM »
It sound like your EGR is stuck "open" This will cause it to die or run rough at low rpm. The EGR should only allow exh. to flow back into the intake at "high" rpm. If it gets "stuck open" or the vac. tells it to open at the wrong time (low rpm) then your motor will do just what you said. Check it out & see if the ERG system is getting hot at idle. Should be cold if closed.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: February 24, 2006, 09:36:12 PM »
Thanks in advance,
Jerry
Curious.
My '93 16v occasionally dies when the accellerator is pressed when the light traffic turns green or at other similar situations.  Is this similar to what is happening to you?  Because it's the older OBDI, I am not sure exactly how to get the codes read...
Ack
  • 85
« Reply #3 on: February 28, 2006, 09:00:12 PM »
Ack,
No, mine dies after letting off the gas and pushing the break to come to a stop (in the middle of a turn no less).  Try Autozone for the codes.  They always ask me what year mine is.  I'm not sure if that is because they don't do the OBDI or just need to know which to bring outside.
ToyYoda,
I'll check that out by feeling the valve tomorrow.  It hasn't died in a few days now but the rpms drop drastically at a stand still like it wants to die.  Is there more to the EGR system than just the valve?  I know there are some hoses (vac?) that lead to another part up on top of the motor.  Could that be bad and if so how could I tell?
Thanks much,
Jerry
« Reply #4 on: March 01, 2006, 02:57:07 PM »
Thanks much,
Jerry
There is a valve controlled by the ECU that switches the vacuum through to the EGR. Usually mounted near the front of the block
Offline All4Traction
« Reply #5 on: March 05, 2006, 09:48:33 PM »
Hey, im new.  I have the same problem with a very low idle when coming to a stop.  Once i get stopped though, the idle bounces back up to where it should be.  When it starts to die it somehow idles pretty much down on the tach peg.
Ive taken off the egr valve, cleaned that filter off, still didnt do anything.
Took off isc valve, blew it out, put a new gasket on it, still does it.
Some time this week im gonna put in a new pcv, it looks kinda loose in the valve cover.
Supposedly someone had the same problem near me and took it to a couple dealerships and none of them could figure out what the problem was.
BTW, i drive a 93 sidekick 4dr.
89 Celica Turbo4wd
93 Suzuki Sidekick 4dr. 16v
« Reply #6 on: March 05, 2006, 10:06:55 PM »
   I had the exact trouble on my 95.  There is a screw (Idle Air Adjustmt Screw??) near the battery under a rubber cap.  I turned this screw 1/4 turn, problem solved!  Only thing is, I can't remember if it was clockwise or counterclockwise!  Here's Wildweasel's pic of the screw:  http://home.comcast.net/~icepoint/P1010014.jpg
« Last Edit: March 05, 2006, 10:21:59 PM by LilRed »
« Reply #7 on: March 05, 2006, 10:29:51 PM »
but it only starts to die sometimes, and there is no rhyme or reason to it.  Itll idle fine most of the time, but sometimes itll almost die coming to a stop, then idle back up to where it should idle once i have fully stopped.
I dont know if its just a coincidence, but it doesnt seem to do it as much on a full tank of gas, i dunno.
89 Celica Turbo4wd
Offline josh9465
« Reply #8 on: March 13, 2006, 02:37:52 AM »
i have the same problem. engine dies when i come to a stop sign. seems to only happen when the engine is cold.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #9 on: May 14, 2006, 01:11:01 AM »
Bump,
Did anyone fix this? other than the idle screw? I am wondering why I would need to adjust that if it is set their from the factory.  It seems like something else has changed and we are compenstiong for potentially another problem. Not saying the screw method won't work, In fact I am going to try it cause stallig while I push in the clutch and come to a stop sucks.
I had a similar issue with my Dodge ram and it was the speed sensor... Anyone know where that is on these things? Is is in the dash or on the T-case?
« Reply #10 on: May 14, 2006, 01:18:31 AM »
Yes the vss is in your speedo, mine is a small reed switch next to a small round disk with a magnet inside it, the disk is inline with the speedo cable, yes it will cause it to stall at a light and cause bad gas mileage when they go!
« Reply #11 on: May 14, 2006, 08:07:00 AM »
If it only happens when its cold then it could be the temperature sensor.
Offline locjaw
  • 2045
  • 22
« Reply #12 on: May 14, 2006, 08:53:05 AM »
this fix will solve all your problems.
this idle screw, over the years, backs out from the vibration of the motor ;)
i think you turn it clockwise
jason
Offline jzap
  • 515
  • How difficult can it be?
« Reply #13 on: May 15, 2006, 06:33:41 PM »
Another thing to check is the tube that goes from the EGR to the manifold (steel tube).
Mine was clogged at the manifold end with carbon.  Take it off completely (4 10mm bolts), and run a wire through it.  Also clear the port in the manifold because it may be plugged too.  Unblocking the tube and port fixed this problem on my '96 and cleared the EGR code after about 30 miles of driving.
Jim Z.
66 Apache camper
Offline Zimo
  • ASE certified mechanic
« Reply #14 on: May 17, 2006, 01:02:31 AM »
Mine is doing the same thing right now. The screw in the back did keep it from stalling, but the idle still goes up & down 1200 rpm - 1900. I think the problem is the timing advance. Is there a way to lock it out & just set it at 35 degs?
Does anyone know which wire on the distributor or VSS controls the advance?
'95 Tracker.
