while the engines out...
trailtracker
44
the fixing/modification is endless!
February 27, 2006, 02:57:03 PM »
is there anything i should do? Anything you i can do in my garage to add a little more performance to the 16v tracker engine? any maintenance that i can do easier now? trannys out too.... by the way, would anyone know where i could get two transmission boots? the lowest ones that go right on the tranny and the tcase shifters? both mine are cracked and are letting some water get into the fluid. thanks in advance
Unsafe at any speed
mrfuelish
2862
13
you must have a perception problem.
Re: while the engines out...
February 27, 2006, 11:02:07 PM »
call trail tough,they sell a better than stock rear main seal, it's not cheap but should last a long time, check your clutch and bearings if you have one, change your timing belt and cam seals, water pump also.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
92Sidekick4x4
1456
Spencer Atkinson, 92Sidekick4x4
February 28, 2006, 01:30:44 PM »
check the clutch on it, if its on its way out may was well do that as well.
my lug nuts require more torque then my engine makes
