Wirering up accessories?
  • 9 Replies
  • 3014 Views
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« on: March 01, 2006, 04:26:56 PM »
What can I fit to the Vitara to run all the accessories through, instead of keep adding to the battery positive terminal.
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Re: Wirering up accessories?
« Reply #1 on: March 01, 2006, 07:52:12 PM »
What I ended up using was a fuse block from a local auto parts store.
It has 1 main wire that goes into it and 6 fuses that go out.
« Reply #2 on: March 01, 2006, 07:59:12 PM »
How much does one of those run?
'86 MJ, 2.5 AMC, 904, NP207
'85 GMC HD2500, 350, 33s
'84 Toy, 20R, fenders cut like an emo kid
« Reply #3 on: March 02, 2006, 05:23:23 PM »
If I remember right. It cost me 8 bucks and that was a few years ago.
I picked up a spare one planning on using it on the 4dr. ;D
Offline tOnKa TrAcKeR
  • 264
  • support our troops
    • Cardomain site
« Reply #4 on: March 03, 2006, 10:39:15 AM »
thats the same thing i did for all of my KC lights except mine has 8 fuses
Offline takai
  • 907
« Reply #5 on: March 03, 2006, 04:19:46 PM »
That is a really good idea. I will have to remeber that.
'Cause, I am to misbehave.
Offline GeoB
  • 11
« Reply #6 on: March 03, 2006, 06:32:06 PM »
I have a buncha lights that I wanna power properly on my rig.  Driving lights, rock lights, extra back-up lights.. I also want to be able to power additional accessories, like a lil air compressor for my diesel horns!   ;D  I have a few things in mind I wanna add.
I burned out one of those 'cheap' Pepboy lighting solenoids that cost about $10 now.  I bought a bag of 10 heavier duty 30A solenoids on eBay for $10 instead.  These are the square black ones that come with most of the starter-fix kits and off-road light kits.
I don't have space to mount solenoids and string wires all over under the hood.  So I am building (planning and acquiring parts) a board (thin fiberglass) upon which I will mount several relays and maybe some extras too.  I will have a powered terminal strip, a switched-power strip, a ground strip, and a strip for the output from the solenoids, plus a terminal strip to connect the signal lines for the solenoids.  I guess I have pert near everything.  I have a coupla fuse blocks, one off of an RV, one off of my spare Sidekick.  I have some of those circuit breakers that plug in like fuses.  I have a tin-top rear window defroster switch for a master switch to the panel.  I guess I have most everything except not enough switches.  And I prolly have those in boxes somewhere.  Also I thought I would build a small board to mount under the radio or somplace with the toggle switches on it.
"The liberty of a democracy is not safe if the people tolerate the growth of private power to a point where it becomes stronger than their democratic State itself.
That, in its essence, is Fascism - ownership of government by an individual, by a group or by any controlling private power."
                                                         --FDR
Offline toolman21
  • 229
« Reply #7 on: March 06, 2006, 08:50:58 AM »
If you have a bunch to do, it might be easier to use something like this.  They also have weather resistant versions.  Not the cheapest option, but the quailty is outstanding.
http://www.painlesswiring.com/webcatalog/cat-fuseblock.htm
Toolman
Offline suzukiboyoz
  • 194
« Reply #8 on: March 06, 2006, 02:14:05 PM »
Thanks for that is what I am looking for, just got to work out which one I need.
Offline Baloo
  • 84
« Reply #9 on: March 09, 2006, 04:54:56 PM »
I have not done it to the tracker but my land cruiser has two extra fuse bloks one is hot always, one is hot in the run position only. I do not like to add to the factory block unless there is an empty spot. Just my $.02. :)
