drum service limit
  • 1451 Views
Offline KickTurn
  • 53
  • My wife likes the smell of petroleum products.
drum service limit
« on: March 01, 2006, 11:40:05 PM »
So, the standard drum size is 10.00" and the drum service limit is 10.07" . . . What's up with that?  Seems like a tiny amount of allowable wear and/or turning: 0.07" or two millimeters!  Much less allowable wear than, say, my Rangers.
Any input?
Thanks!
____________
1995 Sidekick JLX 4Dr; 1.6, 16 valve
95 Kick JLX 4x4 4dr 1.6 16v.
235s, manual hubs.
Re: drum service limit
« Reply #1 on: March 02, 2006, 10:17:57 AM »
If you let them wear too far you might have trouble getting them off. However I make that 1.778mm, which is less than a 1mm of wear 'groove', I wouldn't replace them with that little wear on them. I find it hard to believe that they will run out of adjustment or that the pistons will extend past the seals as long as you don't run the shoes right down.
Edit: The FSM for the Jap swb gives a wear limit of 0.08in dia. Mine were worn much more than that but they they did leak a little when the shoes got down to the metal (I hate sand!)
« Last Edit: March 02, 2006, 10:20:46 AM by Rhinoman »
