Alignment
  • 1831 Views
Offline fRESH_OiL
  • 14
  • 98' Sport, Rocksteady
Alignment
« on: March 02, 2006, 09:15:30 PM »
So a few weeks back I installed a lift and tires and basically everthing in my profile that has been done at the same time. The first 3 weeks it was all shaking, i assumed form the alignment. Now as time goes by the shaking has kinda gone away... almost not there at all. I know I should still get an alignment... but is this a good thing of a bad thing?
"El Duende" 98' Sidekick Sport JLX, OME Spring/Struts, DT Shocks, Warn Manual Hubs, 2" Body Lift, 16" EAlloy Wheels w/ 1.3" Spacers, 30" Wranglers. Next, ARB Lockers and Rhino Liner. And install that damn Snorkle I built.
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: Alignment
« Reply #1 on: March 02, 2006, 09:33:19 PM »
was the shaking coming thru the steering wheel or could you feel it thru the seat? either way you should install the upper strut alignment bolts and get it straight or you will wear the insides of your tires real fast. it will also make the truck steer much better.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
