Bosch 2 or 4 Prong Plugs?
  • 23 Replies
  • 7338 Views
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« on: June 20, 2005, 01:31:44 PM »
Do you guys and gals think that there is any advantage to having Bosch 4 prong plugs over there 2 prong plugs?  I'm doing a major tune-up in the following 30 days and I need some input.  Thanks for any info!!! :D
Re: Bosch 2 or 4 Prong Plugs?
« Reply #1 on: June 20, 2005, 03:29:39 PM »
Don't buy into the BS if you think
you are going to get 4 big ole hot
sparks, most of the time the spark
jumps to 1 maybe 2 ground electrodes
For the $$  I think platinum is the
way to go
Offline Natebert
  • 1098
« Reply #2 on: June 20, 2005, 04:11:27 PM »
way to go
Yup!
'lectricity takes the shortest/easiest path to ground, and ~99% of the time through only 1 prong.  This is due to the fact that once the circuit is made the charge is over.
To me the 'quad' plugs are a HUGE sales gimmick, and it's working too!  About the only plus I can see to them as that you won't have to change your plugs as often because as soon as one of the prongs burns up, you've got 3 more there ready to go.
Also, if you get plugs get platnium 'trodes.  They don't burn up as fast as silver or copper.
Offline Suzuki1.8
  • 283
  • Tires so low looks like i'm riding on blades
« Reply #3 on: June 20, 2005, 04:35:22 PM »
I put the bosch 4 platium in my zuki i noticed a difference. but my 1.8 has coil packs. there not to get more spark but a hotter spark. The only real difference i notcied is on high end above six grand i noctied more responsive. It might have something to do with my chip to.  and they were only 1 dollar more a spark plug over the bosch 2 platium.
« Last Edit: June 20, 2005, 04:36:05 PM by suzuki1.8 »
Offline Mythose
  • 361
« Reply #4 on: June 21, 2005, 01:48:28 AM »
NGK VPower platnium, run them in all my cars and trucks, and run regular NGk in my lawn mower chainsaw, and Go-Kart.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #5 on: June 21, 2005, 10:04:58 AM »
Yeah, I've consider NGK...maybe I should just get those.
Suzuki recommends NGK also...
Offline toolman21
  • 229
« Reply #6 on: June 22, 2005, 06:49:53 AM »
I will second the NGK, good plug.  If you are worried about them burning up just replace them more often, I mean only like 8 bucks with tax for a set.
Toolman
« Reply #7 on: June 22, 2005, 08:24:55 AM »
NGK V plugs have worked very well in all of my vehicles. I tried the 4 prong NGK plugs once and was very dissapointed, curiously they didn't last anywhere near as long as the Vs.
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #8 on: June 22, 2005, 11:19:10 AM »
I couldn't believe what changing my plugs (bosch plat4s) and wires did to my car! I noticed instantly better performance and a little bit of better fuel economy. Guess it just burns better and cleaner... Is a hotter ignition coil a next good step in that area? I'm sure there's something out there that burns a little hotter than what my stock coil does...
steveo
Offline Craw4x4PH
  • 121
  • www.4x4ph.com
    • 4x4 Philippines
« Reply #9 on: June 22, 2005, 03:45:59 PM »
Then if the cost of the 4-pronged ones cost just around double the 2-pronged ones it should be the same, so get the 4-pronged ones so you'll just have to replaced it after a longer time than usual...
[/url]
[/url]
Offline Mythose
  • 361
« Reply #10 on: June 23, 2005, 01:47:28 AM »
I use NGk so I dont have to replace them as often, I put the Bosh 4 prong crapers in my acura,"some arse at shucks recomended it for better preformance", 100 miles and 4 bad plugs, put the NGK in and 2000 miles later no problemb, also i used to run the autolight plugs in the Suburban, sposed to be better for american cars "yeah like atom boms are good for the enviroment" keept fouling the plugs ever 2 or 3 days, had to take um out, clean um off with a NYLON brusn, NOT WIRE!!! and put them back in, it has had the NGK in it for 4k miles and they are not fouled, should be replaced but it runs just as good as it would with new plugs :-/ so it needs an oil change to but BAH, 15 bucks at Wally world.
Offline Mythose
  • 361
« Reply #11 on: June 23, 2005, 01:49:21 AM »
Err 6 bad plugs in the acura and at almost $6 each I about showed that sales person were to screw them in!!!
Offline Suzuki1.8
  • 283
« Reply #12 on: June 23, 2005, 11:56:13 AM »
i got a question. how is the world you fouling so many plugs? last time i fouled that many plugs was when i mixed the oil and gas wrong in my dirt bike? :D
Offline Mythose
  • 361
« Reply #13 on: June 24, 2005, 03:42:25 AM »
I duno but it fouled all the bosh plugs, and i have not had any problemb with the NGK.
« Reply #14 on: June 24, 2005, 09:31:16 AM »
Sounds like the wrong heat range.
I ran NGKs in my Honda VFR750, was supposed to change them every 8,000 miles. Every time time I took them out they looked like new. Still did 50mpg and 100-130mph in under 10secs (my test for 'needs a service'  ;D). I ended up changing them at 24K (I did 50K a year). I ran one set for 35K before I thought I had better change them 'just in case', the new ones didn't make any difference.
« Last Edit: June 24, 2005, 09:32:13 AM by Rhinoman »
