Brakes on Sammy Toyota swap--AXLE HELP
  • 1694 Views
Offline Erickson00
  • 24
« on: March 08, 2006, 05:12:30 PM »
Just starting the v6 build up on the zuk and am going to change the axles but still havent decided, i dont know too much about switching axles n what not. I was wondering how braking works? if you put yota axles on it? thanks i am really struggling with the axles choice i am going to have a v6, 8 inch coils and run ethier 33s or 35s and need to figure out what and how the axles i am going to run and suggestions? would stock sammy axles hold up? or what? thanks as i said i am really having problems this axles thing doesnt make sense to me no problem with motor and lift jus these damn axles!!!!
thanks again BRAD
Offline sj416 nz
  • 38
Re: Brakes on Sammy Toyota swap--AXLE HELP
« Reply #1 on: March 09, 2006, 12:20:52 AM »
go toy axes!!
I am running toy axes with 4.88 r&p and 5.14 t-case and RRO coil kit love it.
way stronger (you will problem will brake stock axes)
brake lines bolt up (standard hilux)
you have to get a adapter for the drive shaft (diffrent bolt paten)
steering arms have to be made or buy a kit
new rims
still finishing mine got a few problems with the rear wheels
locking up need to try a diffrent proportioning valve.
with the coils are you getting 8" lifted over stock
or 8" tall  the coils on the rro kit are 14" coils
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
airtec snorkel RRO coil kit toyota running gear 4.88
Offline Erickson00
  • 24
« Reply #2 on: March 09, 2006, 08:42:41 AM »
Hey thanks for the help where would one buy the steering componets for the yota axles? Then also how do u like the RRO kit? I am confused on what you are asking about the 8 inch lift or height? I havent gotten it yet so dont know much about it i just ordered it the other day but i got the 8 inch kit instead of the 6 inch. I think im going to like it i really just dont want to deal with axles! hahah Wish i could afford some custom ones!!!! Are you running 35s? or 33s on ur zuk? any rubbing?/ thanks BRAD
Offline sj416 nz
  • 38
« Reply #3 on: March 09, 2006, 07:33:04 PM »
what coil kit did you order if you ordered the Deluxe Coil kit
for the Toyota axes you will get every thing you need to instill
the Toyota axes.
love the kit but.
1. front bolts on the arms wore not long enough
2. front drive shaft hit the cross member
3. the front panhard bar was on the wrong side(did ask if they made the kit for RHD.)
4. there is a lot of work to put the kit in if you do not know much
about installing Suspension get same one to do it for you.
love the kit flex's well (not sure about the 40")  just needed to get the Steering sorted.
running 32" simexs really 33s and dose not rub at all.
86 sj413
1.6 16 valve
5.14 t-case
32" simexs
Offline Erickson00
  • 24
« Reply #4 on: March 10, 2006, 12:49:18 AM »
sweet pics!! Well i think ill be able to handle the lift, so the toyota kit comes with the steering componets for yota axles right? i thought it did but i could be mistaken thanks BRAD
