What stock parts have you broken?
  • 35 Replies
  • 8943 Views
Offline jo-jo
  • 15
  • I love YaBB 1G - SP1!
« on: February 21, 2005, 05:58:51 PM »
Just curious to know what stock parts everyone has broken, and where or what broke on the part.
Please include the truck model, and anything else you'd like to add.  8)
Offline mbmarkyb
  • 461
    • UK Vitara
Re: What stock parts have you broken?
« Reply #1 on: February 21, 2005, 06:16:50 PM »
hello.
I have a Kick/UK vitara. model 1992 softop.
I run 33.12.50s and calmini 6" combo with a few add ons lockers etc.
I have broken a 22 spline inner front drive shaft. a 3rd member mount this was on the same day at a competion so I was giving it all.
Twisted a set of rear shafts
Things broken due to bad maintenance on my side :-(
stock crown wheel front.. too much back lash worn bearings
another front shaft but it was twisted before it went in
Engine blow up but that was down to mis use from the previous owner.
I have lost count of how many alternators and starters and usally change the rear bearings once a year and front about 6 times a year lol :-) about twice a year.
Brake pads and rear shoes every few month depending where i drive.
We hit a lot of sand over here and the mud is thick and nasty
And there it is :-)
Markyb (UK)
UK Vitara JLX SE
Offline explosivo
  • 3157
« Reply #2 on: February 21, 2005, 10:10:27 PM »
Too many Aluminum diff housings (the mounting ears), I've pulled a few CV shafts apart at the cage somehow, had a wheelbearing go out (completely my fault), had a couple fucked clutch cables, replaced the clutch, pressure plate, throw-out bearing, pilot bearing, had the head rebuilt due to a couple burnt valves (previous owner) and probably some other stuff.
omghi2.us[/url]
« Reply #3 on: February 21, 2005, 10:38:17 PM »
Clutch Cables,Many CV's at every possible breaking point, Rear axle shafts, many mufflers riped out, mirrors, riped the stock rear bumper off,headlight, tail light, grill, Locker Pins, Lockout hub, bent frame, bent rims, driveshaft.  I'll post more if I think of it.
89 Kick, Calmini 3+3 modified lift, 5.83's, 4:1, locked front and rear, 33x12.50's, etc........
Offline 1bigtracker
  • 3409
« Reply #4 on: February 22, 2005, 12:17:30 AM »
93 tracker convo
no suspension lift
body lift and cutting
34/9.50R15  Super Swamper TSL's
welded rear axle
lifted engine 3 inchs
skid plates, ect...
it WILL NOT count body damage as broken parts:
4 rear axle shafts
torn 4 CV boots(never broke a CV even when wheeling with a riped boot)
1 exploded front housing
1 front housing with the mounting ear riped off
3 blown tire beads(all at once ;D)
3 broken hub bolts(all my fault)
3 fans(cluchs die after being spun a 6500RPM while submurged in water)
1 front skid plate
1 trans
i think thats eveything
stu
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #5 on: February 22, 2005, 12:32:16 AM »
i forgot about the clutches .   2 clutches 1 did fall apart and the dealer is getting me another ,
How could i forget that weight of the gearbox on my leg lol
rear Prop UJS    forgot that too
Markyb (UK)
UK Vitara JLX SE
Offline Natebert
  • 1098
« Reply #6 on: February 22, 2005, 01:09:19 AM »
Um.
Take off gas cap, valve stem caps, and radar detector,
replace
~Nate
Offline Bfunk
  • 406
« Reply #7 on: February 22, 2005, 01:28:42 AM »
I broke 2 rear axle shafts and 1 rear ring and pinion.  Not that I'm complaining, but I've never broke anything in the front.  Are you guys in reverse when you snap parts or what ???
Brian
« Reply #8 on: February 22, 2005, 01:49:34 AM »
Not me, all of my front end parts were blown apart going forward :-/
Offline real_red_wagon
  • 226
  • Make It Hert!!!
« Reply #9 on: February 22, 2005, 03:31:32 AM »
     Lets see ;D
 1. front locking hubs(unaware till it was too late ;D)
 2. alternator's 4 of them :o (they don't like drowning)
 3. pass upper cv (more than once :P)
 4. front axle houseing and third member(still can't find all the pieces :o)
 5. water pump (no big deal :P)
 6. u joints (so thats not the tread on the tyres shaking the truck ;D)
 7. tailgate handle and door locks (who cares)
 8. smashed the grille pushing another zuke ::)
 9 I'm sure there are others......
    all of which were done makin it hert!!! ;D
At Lakeview Motorsports, were wasting your time already!
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #10 on: February 22, 2005, 05:42:04 AM »
A few U-Joints, 1 rear drive shaft slip yolk, 2 Radiators, several clutches (auto zone clutches suck..lol), 2 steering rag joints, 2 sets of rear wheel berrings, 1 set of springs, 1 water pump...so far thats it (knock on wood!)
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #11 on: February 22, 2005, 05:56:52 AM »
On the Gnewt, I have broken the mounting tab on the front 3rd member carrier.  Replaced with a steel GV 3rd member carrier.  Let's see...
...hmm...
EDIT:  Bent my stock idler arm big time at Zukfari last year.  Replaced with Sky idler arm.
...well, that's about it.  Even with wheeling Moab, and all over the mountains of Colorado, I just haven't broken much.  I must be a wuss driver.
« Last Edit: February 22, 2005, 08:13:28 AM by Bobzooki »
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #12 on: February 22, 2005, 08:04:09 AM »
Sheared the bolts holding the hub on... twice.  ;D
Ends up the springs on the passenger side of the Ez-Locker were sheared in half so it wasn't locking up correctly.
« Reply #13 on: February 22, 2005, 04:16:34 PM »
Stock alum front housing (first time out)
Calmini rear 3rd link (stripped threads)
Rear framed cracked (too much back bumper?, but now fixed for good)
beside that, Nothing else ;D
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #14 on: February 22, 2005, 08:20:00 PM »
Brian
I was in reverse when i did the 3rd and crown wheel.
I might have a pic somewhere but i was in sand backed up against a ledge you couldnt see my 33" tires and I had the rear winch going and i was helping it along when too much torgue and BANG!! lol
an acceptable break as a beefed up Landrover broke a rear shaft on the same part
Markyb (UK)
UK Vitara JLX SE
