Any one welded up a front diff?
  • 9 Replies
  • 2987 Views
Offline kcsmostwanted
« on: March 14, 2006, 06:55:48 PM »
I welded my buddys this weekend and he seemed get around great, exept for his non power steering issue. just wonderd if anyone else had done it with any sucess?  I would like to do it to my daily driver but it has automatic hubs, didnt know if it would be a road hazard.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Any one welded up a front diff?
« Reply #1 on: March 14, 2006, 07:03:19 PM »
Yeah auto-locking hubs and a welded front dif could lead to some interesting suprises... It might be time to scour the salvage yards for a set of Asins.
Are you in Kansas City??  If so there are a couple of Samurais at the pick-and-pull at 12th and Osage in KCK.  Last I looked, two still had their hubs and two didn't (guess who has a set...)
from Independence, Mo --
Ack
« Reply #2 on: March 14, 2006, 07:16:33 PM »
are asins manual hubs I have a some off my 95 will they just bolt on or do I need to change the whole knucle? I am in KC are you local?
Offline purevil71
  • 261
  • Someday when I grow up, I wanna be hardcore too!!
« Reply #3 on: March 14, 2006, 09:06:27 PM »
I'm running a welded front in my sami....Toy axles, 36's and power steering  ;D
88.5 Samurai
Balls Deep 4x4 & Off-Road
I-Zook Staff
« Reply #4 on: March 15, 2006, 05:53:30 AM »
I have two trackers one is stock with 31's and the other I'm still building but I'm putting toy axels in. Does it give you much trouble? Or should I just spend the $ on a lock right. The locker for the toy axel is like $500 >:(
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #5 on: March 15, 2006, 02:54:38 PM »
Welded front sounds plain silly.  A lock-right would be a much less damaging option.
1993 4-door Sidekick
4.24:1 t-case
« Reply #6 on: March 15, 2006, 03:11:24 PM »
I think your probably right but I break front diff housings like they are made of plastic, I'm not sure if a lockright would survive.
Offline ack
  • 1659
    • Ack's FAQ
« Reply #7 on: March 15, 2006, 06:30:39 PM »
Any Asin from a another Samurai should bolt right on (with the snap-ring in place on the end of the axle...).  No knuckle removal at all!
I am in Independence, MO.  PM me.
Ack
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #8 on: March 18, 2006, 11:40:27 AM »
I did it on lil Suzi when I lived in Memphis, It worked great going straight but was hard to turn. I switched over to a lockright in a Samurai carrier, much better. I see that trailtough has a limited slip for the sidekick front for a reasonable price that would work as well. If you are on a severe budget you can tri a poor mans possi by adding extra washers, I think their called thrust washers, to preload the spider gears so they don't turn easily.
Dave
Student of Now Master of Then
Offline purevil71
  • 261
« Reply #9 on: March 19, 2006, 08:49:15 PM »
On 36's its a bear to turn, but doable...But, thats why I'm doing power steering.
I MIGHT do a detroit later on, or hydro assist.  I'm gonna test it some more and see how it does.
I will admit that a locker in front is easier to turn than a welded front.
But if your way short on cash and want a locked front...... ;D
88.5 Samurai
I-Zook Staff
