bRAKE UPGRADE FOR TWO DOOR QUESTION
  • 1945 Views
« on: March 18, 2006, 07:12:18 AM »
I want to do the 4 door brake upgrade ( rotors and calipers) to my 95 two door, what year 4 door parts should I buy? My local Zone just needs a model year year to get the right parts. Also need the caliper hangers I guess, so what year should I be looking for at the salvage  yards? Thanks, anyone?
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: bRAKE UPGRADE FOR TWO DOOR QUESTION
« Reply #1 on: March 18, 2006, 07:39:48 AM »
brakes off of any year will work up to 97 i believe i used 93. when buying the calipers get loaded calipers and they will come with the brackets so youdont have to go to the wrecker.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: March 18, 2006, 07:42:49 AM »
I took front and rear brakes from a 94 4 door for my 91 2 door and everything bolted right up. Just had to trim the tin shield behind the rotors a smidge.  My 91 on 34's stops better than my 4 door on stock tires now.  I think you would be ok to get parts off any up to 98 but perhaps someone knows a bit better than me.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #3 on: March 18, 2006, 08:17:30 AM »
 ;) Thank You Gentelmen! I'm off to the Zone! Bentparts.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #4 on: March 18, 2006, 10:03:45 AM »
Does the stock 2 door master cylinder work for this or is it simply a matter of switching the brake parts down at the ends of the axles?
Offline derekj
  • 784
« Reply #5 on: March 18, 2006, 12:22:46 PM »
you dont need to change the master - it will work.
derek
91 Sidekick jx
2" BDS body lift
1" Coil spacers
Offline mojoincolorado
  • 95
« Reply #6 on: March 18, 2006, 12:32:02 PM »
I used the frnt calipers and the mount (first part that the caliper touches) from a 94 2wd 4 door.  Later, I swapped in a different rear axle from a 98 4 door (for the brakes).  No issues either time.  This is a good time to change ALL your brake fluid.  If nothing else, get a Mity-vac vacuum pump with the brake bleeder kit.  Makes it easy.  I think Harbor Freight even has them on sale.
Enjoy!
