4wd Klunk
  • 2421 Views
Offline TysonS
  • 383
  • www.funinbc.com
4wd Klunk
« on: March 21, 2006, 07:10:59 PM »
Hey,
I just knowtused that when im in 4H or 4L and am turning at a full lock about every 2-4 full tire rotations i get a light klunk noise in the front end.
Is this normal?  It only does it at a full lock, if a turn the wheel 30 degrees the other way it stops so only at a full lock.
Thanks Guys
Offline da_tub
  • 307
Re: 4wd Klunk
« Reply #1 on: March 21, 2006, 07:19:41 PM »
are you on dry ground or snow,mud or any other fun thing to play in???
91 four door ,and some stuff
Offline zuksofhazzard
  • 503
  • them darn Zuk boys
    • MOAB PICS
Re: 4wd Klunk
« Reply #2 on: March 21, 2006, 07:21:38 PM »
Sounds like it could be your front end binding.
If you are on solid ground, in 4wd, and full lock, something has to give. So it is probably the pressure on your driveline.
You shouldn't need to turn full lock under the conditions I mentioned.
Binding isn't noticed when your in snow, sand, or mud. Usually they will provide the "slip".  ;)
Try seeing if the noise is gone when in 2wd.
Offline TysonS
  • 383
  • www.funinbc.com
Re: 4wd Klunk
« Reply #3 on: March 21, 2006, 07:40:22 PM »
It is on hard pack dirt, and i don't knotus it in the snow so...  I guess it is fine.
Offline da_tub
  • 307
Re: 4wd Klunk
« Reply #4 on: March 21, 2006, 07:41:07 PM »
thats what i was tring to say...( ;D
