does anyone have pics of a 85 sj410
  • 2402 Views
Offline HAWAIIBUILTZUKI
« on: March 30, 2006, 11:09:03 PM »
i wanted too see what kind of steering your runnin on a lifted sj410..thanks
Offline blasterfan
  • 54
  • SHEAAAAA
Re: does anyone have pics of a 85 sj410
« Reply #1 on: March 31, 2006, 07:21:04 AM »
ill get some of my 85 tonight
85 tin top: spoa, weber, thourly, mud kings, no rust, shackels bumpers
88.5 soft top: spoa, lift springs, shackels, 1.6L, hybrid real axle, yota drivshafts, 5:13 gears, bumpers, winch, rear rad, 5 points and buckets, ltbs, lockers, custom exhaust, some trail scars and alot of army green paint
« Reply #2 on: March 31, 2006, 11:07:34 AM »
What type of lift are you running?  There are a couple of shots of mine here.  There is a decent shot from underneath over here from two summers back.  ;D I use a high steer arm on one side, but left the stock bar across the center.  I haven't had a problem with bending it, so I figured I would leave it be until I do.
Are you running Samurai axels or staying with the stock 410?
« Reply #3 on: March 31, 2006, 02:54:46 PM »
IM STAYING with the 410 suspension..im gonna do a spring over..
« Reply #4 on: March 31, 2006, 04:54:14 PM »
The previous owner just had a modified Z-steering setup on it.  I swaped to samurai axels, so I don't have any pictures of that setup.
You can use a high-steering kit from the Samurai as you have the same knuckles, but you would need to cut down the cross-over bars to fit your 3" shorter axels.
