NEED HELP carb butterfly not shut all the way
  • 1392 Views
Offline HAWAIIBUILTZUKI
« on: March 30, 2006, 11:32:36 PM »
The gas fills like its too short when i press it..is there a solution.thanks
Offline BigPig
  • 276
Re: NEED HELP carb butterfly not shut all the way
« Reply #1 on: March 31, 2006, 05:36:24 AM »
I'm not sure I understand your problem, but did you check for kinks or sharp bends in the throttle cable?  You can try disconnecting the cable from the carb and working the carb by hand.  If it works good then you likely have a problem with the cable.  HTH.
'89 Sidekick w/ 4.5" of lift.
